Mode-selector / multistate device
rjnl
Post by rjnl »
Currently i'm working on improving the daikin control script for use with my urura sarara heatpump airconditioner, because the current script is not working ideally for me (i tend to fall back to the remote a lot instead of using the tablet on the wall). Also, the automatic switching between heat/cool based on a temp comparison is not working out, since it tends to flap sometimes between heat and cooling modes. e.g. during daytime when the sun starts heating the room on heating mode it switches to cooling and then back to heating. After I got it working properly i will post this to the relevant topic of course. I wish to implement some support for selecting the mode on the aircon, e.g. ideally i could select (from a dropdown, or a rotator switch, etc.) the mode using a single button. e.g. OFF/AUTO/COOL/HEAT/DRY/HUMIDIFY/DRY COOL/HUMID HEAT/FAN/FRESH. Currently I would need to create a lot of on/off switches and a lot of dirty code and sub/slave device settings to make it sort of easy to use and consistent, but its not really. Also it takes up a lot of "screen estate" on the control devices (app and tablets)
I can imagine some other applications benefiting from this, e.g. lighting scene selector, selecting ventilation settings, bundle all logitech harmony activity switches in a single device/control, displaying presence states, etc.
pj-r
Domoticz version: V3.8650
Re: Mode-selector / multistate device
Post by pj-r »
Dlanor
Post by Dlanor »
Interesting! Maybe it is possible make an multi-state custom switch!
Domoticz| Zigbee | SONOFF
zofiel
Post by zofiel »
yes please! we need a multistate device :)
monty
Post by monty »
would be so useful ..... we need it !!!!
pleeeaasseeeee add it
Regards Monty
westanfelda
Post by westanfelda »
I also would like to have an Switch with 3 buttons for my blinds - down, stop and up. The Blinds stops only by pressing the stop button on the remote :evil:
would be great...at least for me :D :D :D
Guido
abalazs
Post by abalazs »
I also thought about how much it could be resolved by switching to a four-speed fan.
Please be multi-state switch. :)
SQ9MDD
Post by SQ9MDD »
Hi guys, i see new switch type (selector).
Is this work done now?
Because i have some issue, but not sure what i'm doing wrong.
pj-r
Post by pj-r »
Looks like that. I did read thru the pull request and looks like it has int string mapping sql-database. Have to try it at week end.
nmaster
Domoticz version: 3.6304
Post by nmaster »
Hi, I was waiting for this kind of switch for a long time.
I can add a selector switch but does somebody knows how it can be used ?
SQ9MDD
Post by SQ9MDD »
I cant add selector levels i think is not ready yet.
jcjames13009
Domoticz version: 2023.2
Post by jcjames13009 »
Just did a quick test to simulate heating swicth (Off / Eco / Confort). Couldn't make it working with blocky but works fine with Lua... :D
Create Selector Switch with Off / Eco / Confort level name and 3 virtual switches Heating / Heating Eco and Heating Confort
Selector SW 1.JPG (67.64 KiB) Viewed 17139 times
Selector SW 2.JPG (32.35 KiB) Viewed 17139 times
and a lua script
-- script_device_SelectorSwitch_TEST.lua
-- Commande Selector Switch
if (devicechanged['Selector Switch'] == 'Off' and otherdevices['Test Chauffage'] == 'On') then
	commandArray['Test Chauffage']='Off'
	commandArray['Test Chauffage Eco']='Off'
	commandArray['Test Chauffage Confort']='Off'
	print('Test Chauffage Off')
if (devicechanged['Selector Switch'] == 'Eco' and otherdevices['Test Chauffage Eco'] == 'Off') then
	commandArray['Test Chauffage']='On'
	commandArray['Test Chauffage Eco']='On'
	print('Test Chauffage Eco')
if (devicechanged['Selector Switch'] == 'Confort' and otherdevices['Test Chauffage Confort'] == 'Off') then
	commandArray['Test Chauffage Confort']='On'
	print('Test Chauffage Confort')
FYI I use Domoticz V2.3852
Will use it for bathroom heating control
Thanks for this new feature :D
JC
SQ9MDD
Post by SQ9MDD »
I'm confused, how can you did this?
I have a problem with selector cant add levels simply this button doesn't work, and after save dont have any option. :shock:
Dnpwwo
Post by Dnpwwo »
Very nice, simple to use and looks good.
Congrats!
SQ9MDD
Post by SQ9MDD »
OK i see now, i can add selector type dummy switch. But with mysensors switch this future doesn't work.
jcjames13009
Hi SQ9MDD
That's the config I use (Dummy switch). I don't have mysensor.
JC
Last edited by jcjames13009 on Friday 08 January 2016 8:39, edited 1 time in total.
jcjames13009
What is missing is to have different icon for each level :D
SQ9MDD
Post by SQ9MDD »
Right, and possibility to changing lvl 0 name. Sometimes we need a selector for operating modes, changing types of behavior, not only for start/mode/stop.
And another BIG question: they are plannig add selector to the mysensors?
nmaster
Post by nmaster »
Thanks jcjames13009 it's exactly what I need for my heating system.
jcjames13009
Still testing...
Planing is working fine with dummy selector switch
Selector Switch 2.JPG (62.88 KiB) Viewed 16976 times
Selector Switch 3.JPG (32.58 KiB) Viewed 16976 times
and blocky as well
Selector Switch.JPG (37.56 KiB) Viewed 16976 times
2015-12-23 22:06:49.445 Selector Switch sur Eco
2015-12-23 22:06:49.445 EventSystem: Event triggered: Selector SW_2
2015-12-23 22:06:49.159 (Virtuel) Light/Switch (Selector Switch 2)
2015-12-23 22:07:34.096 Selector Switch sur Confort
2015-12-23 22:07:34.096 EventSystem: Event triggered: Selector SW_3
2015-12-23 22:07:33.871 (Virtuel) Light/Switch (Selector Switch 2)
2015-12-23 22:08:08.050 Selector Switch sur Off
2015-12-23 22:08:08.050 EventSystem: Event triggered: Selector SW_1
2015-12-23 22:08:07.843 (Virtuel) Light/Switch (Selector Switch 2)
Just multistate icon is missing. Sure we'll have it soon :D
JC
