User based on ip address
By default all devices connecting to Domoticz from the internal network are logged in as admin user. I have several devices that i would like to login as a different user. (Tablets on the wall). A simple solution could be to add an IP address field to the user record, and if a device connects from that ip the assigned user is used to login.
- gizmocuz
Re: User based on ip address
You can add those ip addresses in the local network setting in the settings page
I also like this to achieve, can't see how to set it in the settings?
- gizmocuz
Okey, I got some ideas.... now the time to implement it
Could you share your ideas
