User based on ip address
pepijn
Post by pepijn »
By default all devices connecting to Domoticz from the internal network are logged in as admin user. I have several devices that i would like to login as a different user. (Tablets on the wall). A simple solution could be to add an IP address field to the user record, and if a device connects from that ip the assigned user is used to login.
gizmocuz
Re: User based on ip address
Post by gizmocuz »
You can add those ip addresses in the local network setting in the settings page
Raspberry Piet
Post by Raspberry Piet »
I also like this to achieve, can't see how to set it in the settings?
gizmocuz
Post by gizmocuz »
Okey, I got some ideas.... now the time to implement it ;)
pepijn
Post by pepijn »
Could you share your ideas ;)
