Domoticz App for Windows Phone
jackslayter
Domoticz version: stable
Post by jackslayter »
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
DavidM84
Re: Domoticz App for Windows Phone
Post by DavidM84 »
I work on it.
What do you think about ask me any impovement?
dijkdj
Post by dijkdj »
Hello David,
My wife uses the WP app:
Possible improvements:
-Fit more switches on one page: Space is taken now by info lastaccess/type switch. I think you can put it in a smaller font
-Make roomplan accessible
If I think of more I will add it. Good work!
DavidM84
Post by DavidM84 »
Cool the change was already done but I have to test on different size to be sure, I have a 1520 the size always seem good tonight I test on my wife's 920 to see and perhaps tomorow we will send a new version, So for the room plan I have to make any think like configure it on my server....
jackslayter
Hi, it is possible to add https with private certificate (login) ?
Thank you
DavidM84
Post by DavidM84 »
jackslayter wrote:Hi, it is possible to add https with private certificate (login) ?
Thank you
How can I configure my raspberry to have https, did you have a tuto to save time ? If I configure mine I will have to implement it ;)
jackslayter
globalassist
Post by globalassist »
Works great! Could use a better translator for Dutch. Can I help?
DavidM84
Post by DavidM84 »
globalassist wrote:Works great! Could use a better translator for Dutch. Can I help?
Of course perhaps by private message
superwifly
Post by superwifly »
Hello, im trying to configure the app in my windows phone but any kind of configuration i put in the conection settings of the app i get the error "connection error". I tried mading the connection in the local lan and i tried with nating across internet (opening the correct ports). I tried with autentication of web site and without ( i tried mading basic auth to)
Can you help me plis? i dont know what is the problem.
King regards.
Kouseri
Post by Kouseri »
DavidM84 wrote:Hello,
I work on it.
Hi David,
I would like to start learning Windows (Phone) development and I would like to do an app which modifies user variables of Domoticz. More information about the idea can be found from here. I was just thinking how the app would interact with the Domoticz. So could you reveal how your app is interacting with the Domoticz? Are you using json queries or something else?
MaffeMuis
Domoticz version: 3.9483
Post by MaffeMuis »
Not working in Windows 10 phone.
Can not scroll in the settings, so i can not set it up.
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
zofiel
Post by zofiel »
Hi David,
Thanks a lot for your work. Could You improve NFC into domoticz mobile app? thanks in advance!!
gcoupe
Domoticz version: v4.10717
Post by gcoupe »
Not working in WP8.1 either.
Can't scroll down the Connexion page to set it up.
The UI is in French - I assume middle icon at the bottom of the screen is to get into Installation settings. But the icon is greyed-out, so I can't select it.
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Not working in win10 :(
It's nice to be important, but it's more important to be nice
Scooter ;)
Isane
Domoticz version: Stable
Post by Isane »
thecosmicgate wrote:Not working in win10 :(
Send DavidM84 a message?
DavidM84
Post by DavidM84 »
Interesting... I use it on my 1520 with Windows mobile 10 but perhaps it'is due to the scroll problem in settings(I didn't see it with my screen),
So I'm testing any correction I had done for me perhaps I will send any update in the next week
DavidM84
Post by DavidM84 »
superwifly wrote:Hello, im trying to configure the app in my windows phone but any kind of configuration i put in the conection settings of the app i get the error "connection error". I tried mading the connection in the local lan and i tried with nating across internet (opening the correct ports). I tried with autentication of web site and without ( i tried mading basic auth to)
King regards.
Hi, perhaps you have to test the connection via internet explorer before so if you are in local lan you don"t have to specify user password
DavidM84
Post by DavidM84 »
I work on it.
Hi David,
Yes of course, I used rest request if you want to update a user variable you can send
GET /json.htm?type=command&param=getuservariables
that return a json data where you identify your user variable and after you ca send this request
GET /json.htm?type=command&param=updateuservariable&idx=(your uservariable idx)&vname=(your uservariable name)&vtype=2&vvalue=(the value), vtype = 2 is string type
thecosmicgate
Running Win10 (not the phone version) on a tablet . but not possible to install
Scooter ;)
