Measure device consumption cheap way?
ThinkPad
Post by ThinkPad »
I am looking for a cheap power meter that i can use the measure the power consumption of a device. I don't want to buy a Z-Wave plug, or Plugwise. Both too expensive for me, and i think the job can be done cheaper.
While browsing around, i found this: Conrad.nl: Voltcraft SEM-3600BT 3-in-1 Smart-energymeter.
Does anyone has experience with such a meter? It connects to your smartphone over Bluetooth (4.0). Would it be possible to retrieve the data by using a Bluetooth stick and a script to parse the data and store in Domoticz?
I also found this: https://www.conrad.nl/nl/gembird-egm-pw ... 52678.html
Which seems spot on, but too expensive :( Also, a wireless version would be better.
I know the Kankun smart socket, but it can't measure power consumption. Plus, i don't want to run heavy loads like my washing machine (2200W or so?) through it.
I also found this: https://www.conrad.nl/nl/voltcraft-ener ... 23049.html which protocol (868Mhz) already seems to be deciphered. But what i read about it, is that it is not quite simple to get working, and also is quite CPU-intensive.
Can't be that i am the only one who finds this interesting :mrgreen: ?
ThinkPad
Re: How to measure consumption of device in a cheap way?
Post by ThinkPad »
Someone at Tweakers just gave me a link to this one: D-Link DSP-W215 Smart Plug.
That one can switch devices, but also measure energy consumption!
Datasheet: http://www.dlink.com/-/media/Consumer_P ... DEU_EN.pdf
Does anyone see a reason not to order it, to fiddle around with it? Would be great if it could be connected to Domoticz with some kind of script. Functionality i am aiming at: If washing machine usage is lower than xx Watt after 1,5h THEN send_message = Washing machine ready! Go empty it you lazy bastard! :lol:
Edit: Someone already seems to have exploited this thing: http://www.devttys0.com/2014/05/hacking ... mart-plug/
But i don't read anything about measuring power consumption....
Teardown video of the device: https://www.youtube.com/watch?v=rjry28Ym7kI
Relay seems to be rated for 16A 250V (can be seen at 11:53).
Reaaaaally tempting to get one, think i'll will order it to see if i can extract the data with a script. >>> OK, got one (i live near a shop that has them). Will try to get data out of it after dinner.
crisman
Post by crisman »
You can also check for the Belkin Wemo Insight switch http://www.amazon.co.uk/Belkin-F7C029EA ... mo+insight it can switch on/off the devices and also measure consumption and give the cost kw/h.
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
What about http://www.neur.io?
I got one. It is promising although not yet capable to detect all appliances.
Looks expensive at first sight but when working you control anything consuming electricity.
Rfxcom
Raspi 4
dijkdj
Post by dijkdj »
Kankun smart plug 2 can measure power use, but app is still chinese :( and you still have the 2200 watt limit
ThinkPad
Post by ThinkPad »
I already bought the D-Link DSP-W215 ! :D Now fiddling with it, to see if i can extract the measured watts from a webpage or so....
I am watching this video: https://www.youtube.com/watch?v=rjry28Ym7kI he does very interesting stuff with it
ThinkPad
Post by ThinkPad »
Ok, i will bring this D-Link DSP-W215 smartplug back to the store tomorrow.
The guy in the teardown video on YouTube could access a webpage on his module (it runs lighttpd) which also states the current power consumption. Unfortunately my module / firmware revision doesn't have a 1:1 equal page like that. I can see the page he describes, but the line with the power consumption is not there.
I also set up the app on my tablet, with which you can control the plug. It works via cloud. I set up an extra accespoint and connected it trough my laptop (bridging connection) and started Wireshark. Logged for a while and i could see the communication between plug <> cloud. Unfortunately when data is requested/sent by the plug, it is encrypted with TLSv1 so unreadable.
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Cheaper than this? 25€ !
http://www.ezhome.nl/koopjeshoek/eversp ... be-fr.html
BE-FR is in general not a problem.
AN158 gives a good contribution to the quality of the Z-wave network.
Measurement comes with all the nice features of Domoticz!
The only disadvantage is, that it does not remember it's state after power down.
Hope this helps.
Domosapiens
(I have 8 of them)
jackslayter
Domoticz version: stable
Post by jackslayter »
I search this device too, I wait your test ;)
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
ThinkPad
Post by ThinkPad »
Hope this helps.
Domosapiens
(I have 8 of them)
That's crazy cheap! Thanks for sharing. Any idea till when this action is valid?
I'm not sure yet if i want to go the Z-Wave route...
tlpeter
Post by tlpeter »
Thinkpad, do it you will like it.
I saw a 30Euro USB stick on the for sale part over here.
Maybe it is still there.
Every or at least a lot of powered zwave devices do measure power.
My roller shutter does too and shows usage for the time used.
dijkdj
Post by dijkdj »
Of course you can also use the Nuon plugs (29,95) of 6node block (49,95) that work on Z-wave. The Zwave upgrade of Domoticz was a relieve after all the cheap 433mhz stuff. Really recommend it!
ThinkPad
Post by ThinkPad »
I think Z-Wave time has just arrived for Mr. ThinkPad :oops:
I just bought those two Everspring AN1586 ... they are dirt cheap for what they are able to do!
Now only need to buy an Aeon labs stick.
I think Z-Wave is the easiest route to go. Couldn't find any other WiFi-smartplug with power measurement when i searched for it yesterday evening.
dijkdj
Re: Measure device consumption cheap way? >SOLVED, Bought Z-
Post by dijkdj »
Wise choice to go Zwave:
There are still a few Wifi options (mostly chinese)
1: Kankun Plug 2
http://ikonke.com/k2.php
2: Broadlink
http://www.banggood.com/Broadlink-SP2-T ... 46435.html
3: Orvibo
http://www.banggood.com/WiWo-S20-Wi-Fi- ... 53743.html
Still, you would have a hard time getting the data to Domoticz. Zwave is the better way.
ThinkPad
Post by ThinkPad »
I have seen those plugs, but it is indeed a better choice to go the Z-Wave route:
- Those plugs don't measure power consumption
- They don't have EU outlets
- I don't trust it to connect a heavy load like a washing machine/dishwasher to it (because of the heating element which easily pulls 2000W )
dijkdj
Post by dijkdj »
Check the links Thinkpad
ThinkPad wrote:I have seen those plugs, but it is indeed a better choice to go the Z-Wave route:
All of these options do measure
Broadlink and ORvibo do
ThinkPad wrote: - I don't trust it to connect a heavy load like a washing machine/dishwasher to it (because of the heating element which easily pulls 2000W )
True
WebSpider
Domoticz version: 4834
Post by WebSpider »
ThinkPad wrote:I think Z-Wave time has just arrived for Mr. ThinkPad :oops:
Thanks for the research :)
I already have some Plugwise devices running (have had them since 2009), but I'm looking for an in-wall measuring + switching solution as well, so this thread came in handy.
An alternative for the Aeon labs stick is the zwave.me raspberry add-on RaZberry, if you already have Domoticz running on a RasPi, like I do.
ThinkPad
Post by ThinkPad »
I run Domoticz on my Synology, which works great.
But besides that, even if i had it running on my Raspberry, i wouldn't have chosen the RaZberry route. A USB-stick is more universal, otherwise if you switch platform you also need to buy a different Z-Wave transceiver.
The two Everspring plugs will probably arrive Tuesday.
davasch
Post by davasch »
The Voltcraft SEM-3600BT seems to be an 'oem'/whitelable product produced by Wittech, named WiTenergy E100. I've found more information on the device at http://wiki.volkszaehler.org/hardware/c ... nergy_e100
ThinkPad
Post by ThinkPad »
Good find, thanks for posting (and specially registering for this).
Did you do anything cool with that device?
