I am looking for a cheap power meter that i can use the measure the power consumption of a device. I don't want to buy a Z-Wave plug, or Plugwise. Both too expensive for me, and i think the job can be done cheaper.
While browsing around, i found this: Conrad.nl: Voltcraft SEM-3600BT 3-in-1 Smart-energymeter.
Does anyone has experience with such a meter? It connects to your smartphone over Bluetooth (4.0). Would it be possible to retrieve the data by using a Bluetooth stick and a script to parse the data and store in Domoticz?
I also found this: https://www.conrad.nl/nl/gembird-egm-pw ... 52678.html
Which seems spot on, but too expensive
I know the Kankun smart socket, but it can't measure power consumption. Plus, i don't want to run heavy loads like my washing machine (2200W or so?) through it.
I also found this: https://www.conrad.nl/nl/voltcraft-ener ... 23049.html which protocol (868Mhz) already seems to be deciphered. But what i read about it, is that it is not quite simple to get working, and also is quite CPU-intensive.
Can't be that i am the only one who finds this interesting
