[347] Additional functionality to Mertik controller
vvhillo
Post by vvhillo »
Please add the UP and DOWN (higher flame, lower flame) functionality.
THNX!
gizmocuz
Re: [347] Additional functionality to Mertik controller
Post by gizmocuz »
Could you check #2304, hope it works ;)
vvhillo
Post by vvhillo »
Will check when I get home...thanks in advance (if it works :D)
vvhillo
Post by vvhillo »
gizmocuz wrote:Could you check #2304, hope it works ;)
The good news is, it works but there is a BUT :)
My Fireplace was protected (with a password) then it does not work. You don't see the popup for the password or the control of the fireplace. If you disable the protection then it just works fine.
jompie
Domoticz version: 3.5877
Post by jompie »
Hi, what do you mean with #2304? Can you explain?
KAKU switches/receivers/Motion sensor/Doorbell
Oregon Temp sensors, TFA Temp sensor
Mertik controller
Raspberry Pi, RFXCom
vvhillo
Post by vvhillo »
jompie wrote:Hi, what do you mean with #2304? Can you explain?
New beta version of Domoticz
gizmocuz
Post by gizmocuz »
Should now be fixed in #2205... please confirm
vvhillo
Post by vvhillo »
Yes works great! Superb job! Thanks!!
jompie
Post by jompie »
Indeed now Up and Down are also working. Please add also these two commands (e.g. as JSON commands):
Run UP/2nd Off
Run Down/2nd On
(thermostat3_sRunUp 0x4
thermostat3_Off2nd 0x4
thermostat3_sRunDown 0x5
thermostat3_On2nd 0x5)
That would be very appreciated
Mertik controller
jompie
Post by jompie »
Commands are added in 2234. Works fine! Thanks a lot.
Mertik controller
vvhillo
Post by vvhillo »
Fireplace up and down don't work anymore since a few updates. If you click up or down a message box is displayed: WRONG CODE. I did not change anything. What is wrong?
abc1000
Post by abc1000 »
In another post, i'm also don't get Domoticz sending to Mertik receiver. Maybe a bug?
I'v firmware 1007 (the latest..) in my RFXtrx433e
