[347] Additional functionality to Mertik controller
Please add the UP and DOWN (higher flame, lower flame) functionality.
THNX!
THNX!
- gizmocuz
Re: [347] Additional functionality to Mertik controller
Could you check #2304, hope it works
Will check when I get home...thanks in advance (if it works )
The good news is, it works but there is a BUTgizmocuz wrote:Could you check #2304, hope it works
My Fireplace was protected (with a password) then it does not work. You don't see the popup for the password or the control of the fireplace. If you disable the protection then it just works fine.
- Domoticz version: 3.5877
Hi, what do you mean with #2304? Can you explain?
KAKU switches/receivers/Motion sensor/Doorbell
Oregon Temp sensors, TFA Temp sensor
Mertik controller
Raspberry Pi, RFXCom
Mertik controller
New beta version of Domoticzjompie wrote:Hi, what do you mean with #2304? Can you explain?
- gizmocuz
Should now be fixed in #2205... please confirmvvhillo wrote:The good news is, it works but there is a BUTgizmocuz wrote:Could you check #2304, hope it works
Yes works great! Superb job! Thanks!!gizmocuz wrote:Should now be fixed in #2205... please confirmvvhillo wrote:The good news is, it works but there is a BUTgizmocuz wrote:Could you check #2304, hope it works
Indeed now Up and Down are also working. Please add also these two commands (e.g. as JSON commands):
Run UP/2nd Off
Run Down/2nd On
(thermostat3_sRunUp 0x4
thermostat3_Off2nd 0x4
thermostat3_sRunDown 0x5
thermostat3_On2nd 0x5)
That would be very appreciated
Run UP/2nd Off
Run Down/2nd On
Mertik controller
Mertik controller
Commands are added in 2234. Works fine! Thanks a lot.
Mertik controller
Mertik controller
Fireplace up and down don't work anymore since a few updates. If you click up or down a message box is displayed: WRONG CODE. I did not change anything. What is wrong?
In another post, i'm also don't get Domoticz sending to Mertik receiver. Maybe a bug?
I'v firmware 1007 (the latest..) in my RFXtrx433e
