LUA error send command TV
- Brutus
Hi guys,
My wish is to make a litte LUA script for sending a JSON command to my TV (standby). This is possible because I have a 2011 or later Philips TV.
I already have a dummy switch that gets activated through a LUA ping script. With the switch off action I would like to trigger this script.
I am trying to understand the logic off lua but I do something wrong and cannot find the solution on the different topics.
This is the script I made (copied/composed) so far.
Script_device_TV.lua:
if (devicechanged['TV Slaapkamer'] == 'Off') then
os.execute('curl -X POST -H "Content-Type: application/json" -d '{ "key": "Standby"}' http://192.168.1.51:1925/1/input/key')
When I put this in my LUA script folder I get the following error message spammed in the logfile:
2015-01-23 23:53:00 Error: ...am Files (x86)\Domoticz\scripts\lua\Script_device_TV.lua:1: ')' expected near '{'
Thanks for the help so far.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
D'rMorris
Re: LUA error send command TV
I notice that you do not close your commandarray:
All scripts should have a return commandArray at the end, maybe that's the issue?
then
- Brutus
Thnx D'rMorris for mentioning this slightly stupid error of mineD'rMorris wrote:I notice that you do not close your commandarray:
All scripts should have a return commandArray at the end, maybe that's the issue?Code: Select all
commandArray = {} if (devicechanged['TV Slaapkamer'] == 'Off') then os.execute('curl -X POST -H "Content-Type: application/json" -d '{ "key": "Standby"}' http://192.168.1.51:1925/1/input/key') end return commandArray
I have tried to run it again after updating the code but it does'nt solve the problem
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
mbulles
I'm using this switch on the On Action Tab for example turning on the Enigma 2 STB
http://root:passw@ipaddress/web/powerstate?newstate=4
and
This action to turn the TV of:
http://root:passw@ipaddress/web/powerstate?newstate=0
This works just fine, but if you intend to not only switch the TV using domoticz but also via your RC than you should use LUA indeed so you can actually check the state of the device to have the switch corresponds the correct active state.
and
Domoticz
Platform: Raspberry Pi B
Protocols: X-10 / RFY / HomeMade P1 Smartmeter USB TTL-RS232-WE on Kampstrup
Hardwarre: CM15Pro / RFXTRX433E
- Brutus
Thnx for your reply.mbulles wrote:Hi,
and
I don't think my Philips TV will accept those commands. My TV uses the Jointspace protocol that needs to be send with JSON. Or do you have A Philips TV to?
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
mbulles
Yes I have a philips Tv.
But I use my GigaBlue DVB-STB Enigma2 receiver to trigger the TV via the HDMI CIC protocol.
So actually I turn on (wake from standby) my DVB-STB which also turns on the TV automatically via the HDMI CIC setting.
Domoticz
- Brutus
Unfortunately I don't have that device so this option will not work with my setup.mbulles wrote:Hi,
But thnx for thinking along.
Greetings
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
Dingetje2004
Hello, just became a domoticz user and saw your post from last year. Did you ever found a solution, since I am facing the same difficulties now? In Domoticz configuration there is only one HTTP Post possible, but I would like to have more and therefore would like to create a LUA Script what will send commands to my Philips TV.
- Brutus
Hi Dingetje2004,
I haven't tried anymore. The TV is question is also sold.
Greetings Brutus.
Greetings Brutus.
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- Westcott
Hi Dingetje2004,
If you use Lua, you can use a Socket, or perhaps a call to curl -
local url = 'curl -m 5 "http://your-url"'
local data = assert(io.popen(url))
Dingetje2004
Thanks, will try 2morrow!
- felix63
- Domoticz version: 2020.1
This might help in controlling a Philips TV... Some complicated (I think) logic to control your TV with a selector switch. Only prerequisite is a way of keep track of the energy consumption of your TV. You can use similar construction to switch sound level. You can use http://ip-address:1925/1/doc/API.html to find all possible commands you can send your TV.
1- obtain IP address of your TV
2- use
3- create a selector switch with values 'Off' and the names from the output of step 2
4- create a local variable ('televisie-status') to keep track of the TV
5- now we need to create a scripts to switch the TV
6. The second script is for checking the status of your TV:
7. That's it. Please not that if your TV has been off - not standby but really of power - it has no IP-address. In that case the switch commands will throw an error and nothing will happen. That means you have to use your remote once to turn the TV on. Thereafter the script and switch will work.
2- use
http://ip-address:1925/1/sources4- create a local variable ('televisie-status') to keep track of the TV
-- Dit script stuurt afhankelijk van de huidige status van de televisie het benodigde commanda om de TV te schakelen.
-- Replace IP-address with the IP-address of your TV
-- Replace NAME-X and ID-X values in the script with the values from step 2, replicate as many elseif's as you need
--Change the values below to reflect to your own setup
local status_uservar = 'televisie_status' -- user variable used to track the state of the TV, values 'On', 'Off' or 'Standby'
local selector = 'TV Bron'
local switch_command = "curl -X POST -H \"Content-Type: application/json\" -d '{ \"key\": \"Standby\"}' http://192.168.178.36:1925/1/input/key &"
if devicechanged[selector'] == 'Off' then
print('TV switch gaat uit')
if uservariables[status_uservar] == "On" then
print('status van de TV is aan, dus we gaan uitschakelen')
os.execute(switch_command)
commandArray['Variable:' .. status_uservar]='Standby'
elseif devicechanged[selector] == 'NAME-1' then
if uservariables[status_uservar] == "Standby" then
print('De TV staat kennelijk uit, dus we gaan de TV inschakelen')
commandArray['Variable:' .. status_uservar]='On'
os.execute("curl -X POST -H \"Content-Type: application/json\" -d '{ \"id\": \"ID-1\"}' http://192.168.178.36:1925/1/sources/current")
elseif devicechanged[selector] == 'NAME-2' then
os.execute("curl -X POST -H \"Content-Type: application/json\" -d '{ \"id\": \"ID-2\"}' http://192.168.178.36:1925/1/sources/current")
-- Dit script checkt het stroomgebruik van de televisie om daaruit de status van de tv af te leiden (On/Standby/Off) en dat vast te leggen in een lokale variabele
local ip_address = '192.168.178.36' --IP address of the Philips TV
local port = '1925' --Port for commands
local tv_status_uservar = 'televisie_status' --Status of the TV (On/Off/Standby)
local tv_source = 'TV Bron' --Selector Switch with possible Sources (now static, could be made dynamic)
local energy_consumption = 'televisie_gebruik' --Name of Z-Wave plug that contains actual consumption of television (in Watts)
local idle_minutes = 1 --The amount of minutes the consumption has to stay below the 'consumption_lower' value
local consumption_upper = 34 --If usage is higher than this value (Watts), the television is on
local consumption_lower = 20 --If usage is lower than this value (Watts), the television is off
local light_sensor = "Woonkamer Lux" --If this switch is on it is dark
local television_usage = tonumber(otherdevices_svalues[energy_consumption])
--Virtual switch is off, but consumption is higher than configured level, so tv is on has started
if (television_usage > consumption_upper) and uservariables[tv_status_uservar] ~= "On" then
commandArray['Variable:' .. tv_status_uservar]='On'
print('Current power usage (' ..television_usage.. 'W) is above upper boundary (' ..consumption_upper.. 'W), so television is on!')
--television is not using a lot of energy, check the counter
elseif (television_usage < consumption_lower) and uservariables[tv_status_uservar] ~= "Off" then
commandArray['Variable:' .. tv_status_uservar]='Off'
commandArray[tv_source]='Set Level: 0'
print('Current power usage (' ..television_usage.. 'W) is below lower boundary (' ..consumption_upper.. 'W), so television is off!')
--television is using some energy
elseif (television_usage > consumption_lower) and (television_usage < consumption_upper) and uservariables[tv_status_uservar] ~= "Standby" then
commandArray['Variable:' .. tv_status_uservar]='Standby'
print('Current power usage (' ..television_usage.. 'W) is between lower and upper boundary (' ..consumption_upper.. 'W), so television is on standby!')
--Check to see if we need to turn some lights on to prevent watching TV in the dark
--if (uservariables[tv_status_uservar] == 'On') and otherdevices['TV'] == 'On' then
if (uservariables[tv_status_uservar] == 'On') then
local http = require('socket.http')
local ltn12 = require('ltn12')
local json = require('dkjson')
if (tonumber(otherdevices_svalues[light_sensor]) <= 2 and otherdevices["Staande lamp"] == 'Off') then
print("Het is donker:"..otherdevices_svalues[light_sensor].." dus we dan wat licht aan")
commandArray['Scene:TV verlichting'] = "On"
--Check actual TV Source and reflect setting on virtual selector switch
t = {}
local url = string.format("http://%s:%s/1/sources/current", ip_address, port)
b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'}
url = tostring(table.concat(t))
local obj, pos, err = json.decode (url, 1, nil)
if err then
print ("Error:", err)
if obj.id == "ID-1" and otherdevices[tv_source] ~= 'NAME-1' then commandArray[tv_source]='Set Level: 10'
print("Selector aanpassen naar NAME-1")
elseif obj.id == "ID-2" and otherdevices[tv_source] ~= 'NAME-2' then commandArray[tv_source]='Set Level: 20'
print("Selector aanpassen naar NAME-2")
elseif obj.id == "ID-3" and otherdevices[tv_source] ~= 'NAME-3' then commandArray[tv_source]='Set Level: 30'
print("Selector aanpassen naar NAME-3")
Trunald
Thank you very much felix63, this is very helpful. Unfortunately I am a completely noob in both Domoticz, and in scripting. I have managed to create the variable, the selector switches, paste the modified script as a saved LUA evenet script, but for the life of me, I cannot figure out how to "call" the script. Not exactly sure whether my selector switches are configured correctly for the purpose, either.
But I am sure I've got the fixed IP of the TV correctly, and Domoticz is communicating with it; I have managed to input text to the TV screen with another script on various events.
I would appreciate your assistance a lot.
- domoticz.jpg (214.9 KiB) Viewed 7722 times
rizzah
Does anyone know how to get the "On" command working on Philips TVs?
I got the Standby working just fine, but it does not respond to "On".
i found this url: http://www.supportforum.philips.com/en/ ... ilips-tv-s
But the POST at the bottom does not work either, simply because the IP is unreachable.
Maybe the wake-on-wlan needs a different syntax?
cipriani
Hi rizzah,
I'm using "cec-client" to switch it ON : my raspberry is connected to my Philips TV over HDMI.
But, when my raspberry restarts, it turns ON the TV, so i've a command to switch it off after restarting...
A new option seems to be available in new Philips TV : wake on lan over Wifi and must be activated on the TV Menu.
I'm looking into this...
Sorry for my english, i'm french :)
rizzah
I have looked into that, i enabled those options (you need to enable that wol over wifi and fast startup also). But the fast start up only works for a period of 4 hours. Atleast you have the ability to set three different times, but with a max of 4 hours. So thats kind of useless.
kofec
If some want. I have created python plugin for Domoticz. Any comment are welcome.
https://github.com/kofec/Domoticz-Enigma2
HenkB
I am struggling with this issue for hours now, and maybe somebody here can point me to what is going wrong.
Goal : turn off the tv trough a virtual switch (SW_TVSTATUS). If this switch gets the status Off , it should run a script that sends a json post to the philips TV.
I do have the CURL working from the command line on the raspberry pi, it woks like a charm.
But when I copy this into the lua device script, it does not execute the code. The script is triggered, I checked by printing a line in the logfile.
So basically : what needs to be changed in the working commandline CURL syntax to get it working in the lua script ?
working on commandline : curl -X POST -d '{"key":"Standby"}' http://192.168.15.61:1925/1/input/key
script_device_TVUIT:
commandArray={}
if (devicechanged['SW_TVSTATUS'] == 'Off') then
print'TV Off...'
os.execute ('curl -X POST -d "key":"Standby" "http://192.168.15.61/1/key"')
I omitted the { and } because if I put them in, I get the error of the topic starter. I assume it is a simple syntax issue, but I do not see it.
commandArray={}
print'TV Off...'
