Watermeter with wireless door sensor and TCRT5000 ?
sheriff
Domoticz version: 2023.1
Post by sheriff »
I use a wireless doorsensor on my gasmeter like the KAKU wireless doorsensor project, and it works very well.
Now i would like to monitor my water meter with a TCRT5000, but do not want to use piface or raspberry gpio.
Would it be possible to use one of my wireless doorsensors, remove the reed contact and attach the digital or analog output of the TCRT5000 to these contacts ?
The removed reed contact just makes connection between the two contacts, is the TCRT5000 usable to replace the reed contact ?
This setup would make a very cheap wireless watermeter counter.
sincze
Domoticz version: 2024.4
Re: Water meter with wireless door sensor and TCRT5000 ?
Post by sincze »
sheriff wrote:I use a wireless doorsensor on my gasmeter like the KAKU wireless doorsensor project, and it works very well.
Why not connect this sensor directly to GPIO pins 3,3v / GND & GPIO? Instructions are available on the forum ;-)
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sheriff
Post by sheriff »
sincze wrote: Why not connect this sensor directly to GPIO pins 3,3v / GND & GPIO? Instructions are available on the forum ;-)
Because i am not using my raspberry for domoticz, only as xbmc media player. I run domoticz on my ubuntu server.
sincze
Post by sincze »
Clear in that case it is an interesting setup :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Gerwin1967
Domoticz version: latest
Post by Gerwin1967 »
Interesting looking for such a solution as well, did you succeed, can you share some pictures and the script you used?
ThinkPad
Post by ThinkPad »
You could also build this with MySensors: http://www.mysensors.org/build/pulse_water
Build an Ethernet gateway (Arduino + W5100 Ethernetshield) or Serial gateway (Arduino connected with USB to your server) and receive the data from the watermeter node (another Arduino, but this one measures the watermeter with TCRT5000).
The needed parts can be obtained cheaply from China, by buying from eBay or so.
MySensors is supported since a few weeks ago, in the beta release of Domoticz.
mvveelen
Post by mvveelen »
I'm interested too in a cheap (preferably ready-to-use) solution for logging the water-usage. Maybe, in due time, there will be something I can use for my watermeter.
sincze
Post by sincze »
Gerwin1967 wrote:Interesting looking for such a solution as well, did you succeed, can you share some pictures and the script you used?
TCRT 5000 can be used for watemeter just fine.
I would not suggest to use the interrupt routines. It gave me a lot of false positives in the beginning.
Watermeter TCRT 5000
All Meters
All Meters
mvveelen
Post by mvveelen »
What would one advice for metering the water usage with a meter like this:
I know there are ready-to-use solutions, but they cost about 80 euro's and for that amount of money I can use a lot of water... So I prefer a cheaper way to monitor the usage and.....something that is easy to make for a n00b as me :D
jossie67
Post by jossie67 »
mvveelen,
I'm working on a TCRT5000, directly connected to GPIO.
It detects the metalpart of the arrow.
Now I have to change the it, so it only sends a puls to my domoticz when the status changes from 0V to 3.3V.
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
mvveelen
Post by mvveelen »
Will that work flawlessly, or is this perhaps a better way: http://www.domoticz.com/forum/viewtopic ... 1103#p6746 ?
That might even be easier to build or mount to the water meter, wouldn't it?
jossie67
Post by jossie67 »
Not sure, I made a small Python script to detect a one rotation. That is working fine now.
Next step is to upload the "puls"to domoticz. Since I running domoticz on Ubuntu VMware session.
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
sincze
Post by sincze »
mvveelen wrote:What would one advice for metering the water usage with a meter like this:
tcrt-5000 will do just fine with this meter.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mistysnip
Domoticz version: 2024.7
Re: Watermeter with wireless door sensor and TCRT5000 ?
Post by mistysnip »
Would the TCRT5000 work with this type of water meters?
sincze
Post by sincze »
Hmm , Probably not as there is not a lot of reflective area the sensor can use
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
