No updates on (Nuon) GreenWave Smartplug 6
MarFan
Post by MarFan »
I installed Domoticz together with an RazBerry on a Raspberry Pi.
Also I bought an (nuon) greenwace Smartplug 6. I configured this device in the Z-Wave UI and see all 6 buttons /sensors and meters.
In Domoticz I also see all these (18) devices.
But, there is no update. The values are not changing.
I can update it manually in the Z-wave UI, and those values are then vissible in Domoticz.
Do I miss any setup or .....
Thank you,
MarFan / NL / 3x RasPi / RfXcom / RfLink / S0PCM-5 / P1
MarFan
Re: No updates on (Nuon) GreenWave Smartplug 6
Post by MarFan »
I figured it out,
The refresh/update is not done automaticly.
There is a command IPaddressRP:8083/ZWaveAPI/Run/devices[X].instances[Y].Meter.Get()
Where X is the device ID
Y : 0 = all plugs
y : 1-6 plug Y on the smartplug
I now created a script (VB) which poll every plug (every 2 seconds 1 plug). This will update Domoticz also
@Rob/gizmocuz is it possible that Domoticz fires this command before getting the values ?
gizmocuz
Post by gizmocuz »
Thats odd... but might be working that way.
Could you not setup the device (in razberry) to automaticly get the values every 10 minutes for example?
I can do this with other sensors...
With kind regards,
Rob
MarFan
Post by MarFan »
gizmocuz wrote: Could you not setup the device (in razberry) to automaticly get the values every 10 minutes for example?
Could you post the setup (screendump), I believe I checked everything and could not find it
In this forum they talk about this problem and solved it, that way
http://www.openremote.org/display/forum ... h+Razberry (search for Meter.Get 2 times)
gizmocuz
Post by gizmocuz »
Maybe it is in underneath the button 'Devices Configuration'.
But maybe this device is not 100% supported yet.
Could you email me (info @ domoticz . com), the output from:
http://IPADDRESS:8083/ZWaveAPI/Data/0
then copy the value of 'updateTime' that you can find at the bottom.
Wait an hour, then issue
http://IPADDRESS:8083/ZWaveAPI/Data/UPDATETIMEVALUE
Where IPADDRESS is the ip address of the razberry device, and UPDATETIMEVALUE is the value you copied earlier
With kind regards,
Rob
garp
Post by garp »
I created a script for Razberry (general Linux) that updates the values. I'm still optimizing the script, so it can be different from time to time :D
! /bin/bash
# Script to update NOUN (Greenwave) smart plugs including smart plug 6 information
# on a Razberry (linux) z-wave controller
# save the script somewhere and add it to crontab with 'crontab -e'
# #min hour day month weekday command
# */1   *    *    *    *     /home/pi/script/updatescript.sh
# Single smart plugs
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[2].instances[0].Meter.Get() -O /dev/null"
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[18].instances[0].Meter.Get() -O /dev/null"
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[20].instances[0].Meter.Get() -O /dev/null"
sleep 1
# Smart node 6 - kitchen table
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[0].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[1].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[2].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[3].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[4].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[5].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[6].Meter.Get() -O /dev/null"
sleep 2
# Smart node 6 - behind the tv
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[0].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[1].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[2].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[3].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[4].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[5].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[6].Meter.Get() -O /dev/null"
Domoticz on Raspberry Pi2 with a RazBerry (V1.0), RFXcom USB, Greenwave (NUON) smart plug 6 & single smart plugs, Fibaro door/window sensors, Cresta temp sensors (433mhz), Z-wave.me wall controller/switch, Z-wave.me dimmer, KaKu ACM3500 etc
gertjuhh
Post by gertjuhh »
If you add "-O /dev/null" to your wget command you don't have to remove files afterwards
garp
Post by garp »
Thx. Tested it and it works like a charm. I updated the script in the above post to the current, running one.
I also added 2 seconds wait time between the querying of each plug on the smart plug 6 in an attempt not to overload the plugs with requests.
CopyCatz
Developer
Post by CopyCatz »
Is anyone using this switch with the aeon stick? I think I'm going to order a few of these :D
antwan
Domoticz version: Latest
Post by antwan »
CopyCatz wrote:Is anyone using this switch with the aeon stick? I think I'm going to order a few of these :D
Have the stick and powerbarr for 2 weeks now. I'm verry happy with it and more zwave stuff on order.
Rob has this for more then a month.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
djgodlike
Post by djgodlike »
It now seems to work directly from domoticz without a script.
Just enable polling for every device and adjust time (under hardware device controller setting from OpenZWave) to 30 sec!
Just installed the greenwave smartplug 6 and 2 single greenwave switches. Confirm both working on domonticz on xpenology with Aeon Z-wave Gen5 stick.
Ps i cannot watch the total usage of the smartplug 6 yet...
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Egregius
Domoticz version: v2024.7
Post by Egregius »
You don't need polling for the Greenwave devices :p
Sneezydevil
Post by Sneezydevil »
Egregius wrote:You don't need polling for the Greenwave devices :p
Do they fully work for you without polling? Do they update (and keep updating) usage and total usage?
djgodlike
Re: RE: Re: No updates on (Nuon) GreenWave Smartplug 6
Post by djgodlike »
No they don't seem to show the watts without polling.
Aeon Labs Gen5 USB
Philips Hue
Plugwise Smile P1
Egregius
Post by Egregius »
Ooh, usage... I don't care about that :roll:
Sneezydevil
Haha was just checking I have several greenwave powernodes on most I have polling disabled since I don't need to know the usage. But on 1 or 2 I switch based on usage, in those cases I have polling enabled.
Since I don't really like polling, you gave me glimmer of hope I could get around using polling on those few that have it enabled.
