No updates on (Nuon) GreenWave Smartplug 6
MarFan
I installed Domoticz together with an RazBerry on a Raspberry Pi.
Also I bought an (nuon) greenwace Smartplug 6. I configured this device in the Z-Wave UI and see all 6 buttons /sensors and meters.
In Domoticz I also see all these (18) devices.
But, there is no update. The values are not changing.
I can update it manually in the Z-wave UI, and those values are then vissible in Domoticz.
Do I miss any setup or .....
Thank you,
Thank you,
MarFan / NL / 3x RasPi / RfXcom / RfLink / S0PCM-5 / P1
MarFan
Re: No updates on (Nuon) GreenWave Smartplug 6
I figured it out,
The refresh/update is not done automaticly.
There is a command IPaddressRP:8083/ZWaveAPI/Run/devices[X].instances[Y].Meter.Get()
Where X is the device ID
Y : 0 = all plugs
y : 1-6 plug Y on the smartplug
I now created a script (VB) which poll every plug (every 2 seconds 1 plug). This will update Domoticz also
@Rob/gizmocuz is it possible that Domoticz fires this command before getting the values ?
Y : 0 = all plugs
- gizmocuz
Thats odd... but might be working that way.
Could you not setup the device (in razberry) to automaticly get the values every 10 minutes for example?
I can do this with other sensors...
With kind regards,
Rob
With kind regards,
Rob
MarFan
Could you post the setup (screendump), I believe I checked everything and could not find itgizmocuz wrote: Could you not setup the device (in razberry) to automaticly get the values every 10 minutes for example?
In this forum they talk about this problem and solved it, that way
http://www.openremote.org/display/forum ... h+Razberry (search for Meter.Get 2 times)
- gizmocuz
Maybe it is in underneath the button 'Devices Configuration'.
But maybe this device is not 100% supported yet.
Could you email me (info @ domoticz . com), the output from:
http://IPADDRESS:8083/ZWaveAPI/Data/0
then copy the value of 'updateTime' that you can find at the bottom.
Wait an hour, then issue
http://IPADDRESS:8083/ZWaveAPI/Data/UPDATETIMEVALUE
Where IPADDRESS is the ip address of the razberry device, and UPDATETIMEVALUE is the value you copied earlier
With kind regards,
Rob
With kind regards,
Rob
garp
I created a script for Razberry (general Linux) that updates the values. I'm still optimizing the script, so it can be different from time to time
! /bin/bash
# Script to update NOUN (Greenwave) smart plugs including smart plug 6 information
# on a Razberry (linux) z-wave controller
# save the script somewhere and add it to crontab with 'crontab -e'
# #min hour day month weekday command
# */1 * * * * /home/pi/script/updatescript.sh
# Single smart plugs
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[2].instances[0].Meter.Get() -O /dev/null"
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[18].instances[0].Meter.Get() -O /dev/null"
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[20].instances[0].Meter.Get() -O /dev/null"
sleep 1
# Smart node 6 - kitchen table
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[0].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[1].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[2].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[3].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[4].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[5].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[21].instances[6].Meter.Get() -O /dev/null"
sleep 2
# Smart node 6 - behind the tv
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[0].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[1].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[2].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[3].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[4].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[5].Meter.Get() -O /dev/null"
sleep 2
wget --quiet "http://10.0.0.29:8083/ZWaveAPI/Run/devices[25].instances[6].Meter.Get() -O /dev/null"
Domoticz on Raspberry Pi2 with a RazBerry (V1.0), RFXcom USB, Greenwave (NUON) smart plug 6 & single smart plugs, Fibaro door/window sensors, Cresta temp sensors (433mhz), Z-wave.me wall controller/switch, Z-wave.me dimmer, KaKu ACM3500 etc
gertjuhh
If you add "-O /dev/null" to your wget command you don't have to remove files afterwards
garp
Thx. Tested it and it works like a charm. I updated the script in the above post to the current, running one.
I also added 2 seconds wait time between the querying of each plug on the smart plug 6 in an attempt not to overload the plugs with requests.
- CopyCatz
- Developer
- Target OS: -
Is anyone using this switch with the aeon stick? I think I'm going to order a few of these
antwan
- Domoticz version: Latest
Have the stick and powerbarr for 2 weeks now. I'm verry happy with it and more zwave stuff on order.CopyCatz wrote:Is anyone using this switch with the aeon stick? I think I'm going to order a few of these
Rob has this for more then a month.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
djgodlike
It now seems to work directly from domoticz without a script.
Just enable polling for every device and adjust time (under hardware device controller setting from OpenZWave) to 30 sec!
Just installed the greenwave smartplug 6 and 2 single greenwave switches. Confirm both working on domonticz on xpenology with Aeon Z-wave Gen5 stick.
Ps i cannot watch the total usage of the smartplug 6 yet...
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
- Egregius
- Domoticz version: v2024.7
You don't need polling for the Greenwave devices :p
Sneezydevil
Do they fully work for you without polling? Do they update (and keep updating) usage and total usage?Egregius wrote:You don't need polling for the Greenwave devices :p
djgodlike
Re: RE: Re: No updates on (Nuon) GreenWave Smartplug 6
No they don't seem to show the watts without polling.Sneezydevil wrote:Do they fully work for you without polling? Do they update (and keep updating) usage and total usage?Egregius wrote:You don't need polling for the Greenwave devices :p
Aeon Labs Gen5 USB
Philips Hue
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
- Egregius
Ooh, usage... I don't care about that
Sneezydevil
Haha was just checking I have several greenwave powernodes on most I have polling disabled since I don't need to know the usage. But on 1 or 2 I switch based on usage, in those cases I have polling enabled.
Since I don't really like polling, you gave me glimmer of hope I could get around using polling on those few that have it enabled.
