Gas monitoring device with an arduino
Equinoxefr
Post by Equinoxefr »
I made a device to monitor my gas meter and report it to domoticz with a RFXcom. I'm using a few components: arduino, reed switch, DHT22 and a RF 433MHz transmitter.
You can find my project on github https://github.com/equinoxefr/gasMonitor
I plan to add a water meter too.
ThinkPad
Re: Gas monitoring device with an arduino
Post by ThinkPad »
Cool!
How do you add it in Domoticz?
And i think you could also modify it to electricity, because the reedcontact works the same like a S0-connection? (close contact on pulse).
Equinoxefr
It sends packet in RFXmeter (433MHz) format for the pulse sensor and oregon v2 for humidity / temp, so domoticz receive it with the RFXcom device every 30s.
For electricity i already have an OWL180 but you can do everything you want with an arduino ;)
Equinoxefr
I had some details of my domoticz setup (in french) on my web site http://www.equinoxefr.org/post/2015/01/ ... -domoticz/
deennoo
Post by deennoo »
Thank you for this
http://domo-attitude.fr
Equinoxefr
I updated my code on github. Now you can disable use of DHT22 sensor.
Pierre
deennoo
Post by deennoo »
Hello Pierre.
I got some probleme using your sensor
look at my graph and numbers, it can be true.
conso gaz.PNG (100.26 KiB) Viewed 5728 times
What i can do ?
Equinoxefr
Did you use serial debugging to check if the pulses are detected ?
LeoS
Post by LeoS »
Hi, can this be adapted to measure weight by using a pressure sensor such as this one:
https://www.sparkfun.com/products/11207
I would like to monitor the weight of a water dispenser and have an alert/reminder when the water level is low.
macieiks
Post by macieiks »
Question about RFLink. This is the module that you are using in this project: https://www.sparkfun.com/products/10534 ?
Because I was trying to use my FS1000A/XY-FST RF Radio but any RFX / RFLink device is recognized in Domoticz. (http://www.pocketmagic.net/using-fs1000 ... with-avrs/)
RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
