How to revert from beta to stable on Pi?
ThinkPad
Post by ThinkPad »
I want to revert from the beta version back to the stable version on my Raspberry.
But how can i do so? I looked in the manual, but didn't found anything about this. Also searched the forum, found some posts from gizmocuz about 'just revert from beta to stable then'. But i can't find HOW to do so :p
Please tell me
SOLVED, also created a wiki page explaining the steps to perform: http://domoticz.com/wiki/Going_back_to_ ... us_version
Last edited by ThinkPad on Friday 26 December 2014 13:22, edited 2 times in total.
mbliek
Post by mbliek »
This should give you the latest stable:
wget http://domoticz.sourceforge.net/domoticz_linux_armv6l.tgz
tar xvfz domoticz_linux_armv6l.tgz
rm domoticz_linux_armv6l.tgz
ThinkPad
Re: How to revert from beta to stable on Pi?
Post by ThinkPad »
Ok, but do i first have to remove the current Domoticz version from the Raspbian OS ?
rron
Post by rron »
No that is not necessary. Just follow the instruction of mbliek, that works.
ThinkPad
Post by ThinkPad »
I got some errors with 'tar', because the folder already existed. But i succeeded by doing this:
  1. In /home/pi i deleted the domoticz folder (sudo rm -rf domoticz).
  2. Then created a new one (mkdir domoticz).
  3. Then go to that directory (cd domoticz).
  4. In that directory, run the wget, tar and rm command.
  5. Then reboot
  6. Domotiz is running now (the stable version instead of beta)
  7. Restore database
  8. Reboot
  9. All done
mbliek
Post by mbliek »
Yes. You needed to do the steps in the Domoticz folder.
But this works also if you wanted to delete the old Domoticz.
ThinkPad
Post by ThinkPad »
I also created a wiki page for it, can be useful for beginners :)
sebitop
Post by sebitop »
thanks for this wiki but just a question :
I understand this method allows only to use the last beta version released, if i want to downgrade to a specific version I need to install domoticz manually from source
including a make which takes around 1h to compile everything
ok so installation done and now i would like to downgrade to a previous version example 2140
so If i'm correct I need to use the following commands :
svn update -r XXXX
make
is that correct ?
if yes the "make" will again run for.. 1h... but why a web update takes only a few minutes ?
I suppose there is a way to downgrade quiclky a system ?
thanks for your help
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
ThinkPad
Post by ThinkPad »
I don't know about that. But feel free to add some extra information to the wiki if needed ;)
sebitop
Post by sebitop »
Ok thanks, once I will find the correct method I will add it to the wiki as it could really help
I understand the latest version is 2125 so if I want to use 2140 I don't know how to do that easily
thanks again for your answer
ThinkPad
Post by ThinkPad »
Another question: i had some scripts in the /home/pi/domoticz/scripts/ folder, that are now gone. Luckily i have made a backup of the SD card before reverting to the stable version.
How can i get the scripts from the img file i created wit 'win32diskimager' without first writing it to an SD card and booting up Domoticz and accessing it by SSH ?
sebitop
Post by sebitop »
maybe you can try to mount your image on your computer to explore the image card and to recover the scripts ?
something like daemon tool could help ?
ThinkPad
Post by ThinkPad »
Not working unfortunately. Maybe booting a linux live CD and then opening it works.
Gonna try it this evening.
ThinkPad
Post by ThinkPad »
I flashed the backup to an SD-card i had lying around. Put that in a second pi and got the files off it with WinSCP.
sebitop
Post by sebitop »
ah ! you did not say that you have a second pi available :)
then you found the solution :)
mbliek
Post by mbliek »
Just run the commands I gave within the Domoticz folder and you don't need to delete everything. Saves you a lot of time.
thorbj
Post by thorbj »
Seems like this don't work anymore. It gives me a 404 error when trying to wget http://domoticz.sourceforge.net/domotic ... armv6l.tgz
When browsing to http://domoticz.sourceforge.net, I find only packages for windows and sd-card images for RaspberryPi, but noe domoticz_linux_armv6l.tgz...
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Hexer
Post by Hexer »
ipad air 2 folie
Wenn du mein Schweigen nicht verstaendest, würdest du nie meine Woerter verstehen. hülle für iphone 6 und iphone 6 plus
mbliek
Post by mbliek »
thorbj wrote:Seems like this don't work anymore. It gives me a 404 error when trying to wget http://domoticz.sourceforge.net/domotic ... armv6l.tgz
try
wget http://domoticz.sourceforge.net/domotic ... armv7l.tgz
Heisenberg
Post by Heisenberg »
Unfortunately it doesn't work for me with the above link:
pi@domoticzpi ~/domoticz $ wget http://domoticz.sourceforge.net/domotic ... armv 7l.tgz
--2015-07-10 21:58:39-- http://domoticz.sourceforge.net/domotic
Resolving domoticz.sourceforge.net (domoticz.sourceforge.net)... 216.34.181.96
Connecting to domoticz.sourceforge.net (domoticz.sourceforge.net)|216.34.181.96| :80... connected.
HTTP request sent, awaiting response... 404 Not Found
2015-07-10 21:58:39 ERROR 404: Not Found.
--2015-07-10 21:58:39-- http://.../
Resolving ... (...)... failed: Name or service not known.
wget: unable to resolve host address `...'
--2015-07-10 21:58:39-- http://armv7l.tgz/
Resolving armv7l.tgz (armv7l.tgz)... failed: Name or service not known.
wget: unable to resolve host address `armv7l.tgz'
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
