How to revert from beta to stable on Pi?
I want to revert from the beta version back to the stable version on my Raspberry.
But how can i do so? I looked in the manual, but didn't found anything about this. Also searched the forum, found some posts from gizmocuz about 'just revert from beta to stable then'. But i can't find HOW to do so :p
Please tell me
SOLVED, also created a wiki page explaining the steps to perform: http://domoticz.com/wiki/Going_back_to_ ... us_version
Please tell me
Last edited by ThinkPad on Friday 26 December 2014 13:22, edited 2 times in total.
- mbliek
This should give you the latest stable:
wget http://domoticz.sourceforge.net/domoticz_linux_armv6l.tgz
tar xvfz domoticz_linux_armv6l.tgz
rm domoticz_linux_armv6l.tgz
Op zoek naar een Domoticz Start Set?
Re: How to revert from beta to stable on Pi?
Ok, but do i first have to remove the current Domoticz version from the Raspbian OS ?
No that is not necessary. Just follow the instruction of mbliek, that works.
Rpi, RFXcom, klikaan klikuit switch,thermosmart, z-wave, espeasy, smartevse
I got some errors with 'tar', because the folder already existed. But i succeeded by doing this:
- In /home/pi i deleted the domoticz folder (sudo rm -rf domoticz).
- Then created a new one (mkdir domoticz).
- Then go to that directory (cd domoticz).
- In that directory, run the wget, tar and rm command.
- Then reboot
- Domotiz is running now (the stable version instead of beta)
- Restore database
- Reboot
- All done
- mbliek
Yes. You needed to do the steps in the Domoticz folder.
But this works also if you wanted to delete the old Domoticz.
I also created a wiki page for it, can be useful for beginners
thanks for this wiki but just a question :
I understand this method allows only to use the last beta version released, if i want to downgrade to a specific version I need to install domoticz manually from source
including a make which takes around 1h to compile everything
ok so installation done and now i would like to downgrade to a previous version example 2140
so If i'm correct I need to use the following commands :
svn update -r XXXX
make
is that correct ?
if yes the "make" will again run for.. 1h... but why a web update takes only a few minutes ?
I suppose there is a way to downgrade quiclky a system ?
thanks for your help
svn update -r XXXX
make
is that correct ?
domoticz on Raspberry Pi + RFXcom LAN moded + wifi
Blyss / DI.O / homemade / ESP / wemos
I don't know about that. But feel free to add some extra information to the wiki if needed
Ok thanks, once I will find the correct method I will add it to the wiki as it could really help
I understand the latest version is 2125 so if I want to use 2140 I don't know how to do that easily
thanks again for your answer
Another question: i had some scripts in the /home/pi/domoticz/scripts/ folder, that are now gone. Luckily i have made a backup of the SD card before reverting to the stable version.
How can i get the scripts from the img file i created wit 'win32diskimager' without first writing it to an SD card and booting up Domoticz and accessing it by SSH ?
maybe you can try to mount your image on your computer to explore the image card and to recover the scripts ?
something like daemon tool could help ?
Not working unfortunately. Maybe booting a linux live CD and then opening it works.
Gonna try it this evening.
I flashed the backup to an SD-card i had lying around. Put that in a second pi and got the files off it with WinSCP.
ah ! you did not say that you have a second pi available
then you found the solution
- mbliek
Just run the commands I gave within the Domoticz folder and you don't need to delete everything. Saves you a lot of time.
Seems like this don't work anymore. It gives me a 404 error when trying to wget http://domoticz.sourceforge.net/domotic ... armv6l.tgz
When browsing to http://domoticz.sourceforge.net, I find only packages for windows and sd-card images for RaspberryPi, but noe domoticz_linux_armv6l.tgz...
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Wenn du mein Schweigen nicht verstaendest, würdest du nie meine Woerter verstehen. hülle für iphone 6 und iphone 6 plus
- mbliek
trythorbj wrote:Seems like this don't work anymore. It gives me a 404 error when trying to wget http://domoticz.sourceforge.net/domotic ... armv6l.tgz
wget http://domoticz.sourceforge.net/domotic ... armv7l.tgz
Unfortunately it doesn't work for me with the above link:
pi@domoticzpi ~/domoticz $ wget http://domoticz.sourceforge.net/domotic ... armv 7l.tgz
--2015-07-10 21:58:39-- http://domoticz.sourceforge.net/domotic
Resolving domoticz.sourceforge.net (domoticz.sourceforge.net)... 216.34.181.96
Connecting to domoticz.sourceforge.net (domoticz.sourceforge.net)|216.34.181.96| :80... connected.
HTTP request sent, awaiting response... 404 Not Found
2015-07-10 21:58:39 ERROR 404: Not Found.
--2015-07-10 21:58:39-- http://.../
Resolving ... (...)... failed: Name or service not known.
wget: unable to resolve host address `...'
--2015-07-10 21:58:39-- http://armv7l.tgz/
Resolving armv7l.tgz (armv7l.tgz)... failed: Name or service not known.
wget: unable to resolve host address `armv7l.tgz'
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
