Native Zigbee scenes (zigpy coordinators, off by default)
- Turn them on in Settings › Available services › Features: Enable native Zigbee scenes (plugin restart needed)
- A scene stores the state of the devices of a group in the devices themselves. One command recalls it on all of them at once, instead of one command per device
- Management › Groups & Scenes: capture, test, re-capture and edit scenes, with an optional comment. A scene can be on only part of its group, and window coverings keep their position
- Each group with scenes gets a Domoticz Selector Switch to recall them from Domoticz, scripts and timers
- Groups: a new group can get the group id you choose, for example to match a remote set on a fixed group
Green Power devices (battery-free and low-energy switches)
- Silicon Labs (EZSP) coordinators. Not available on Texas Instruments (Z-Stack) coordinators, which cannot receive Green Power frames. deCONZ (ConBee, RaspBee): not tested yet, reports welcome
- Admin › Provisionning › Zigbee Green Power: pick the device type, Open for 4 minutes, and follow the pairing in a live log
- Device types: On/Off switch, On/Off switch with dimming, 4-button switch (2 switches, 3 switches or single rocker), or Automatic. Tested with the Sunricher ZGP2801K2-DIM and the NodOn CWS-4-1-00
- Every press reaches Domoticz, even when the switch already shows that state, so your events run at each press
- Management › Devices: a details window for each Green Power device. One that got no widget can be given its type, or removed, from there
Settings page
- Settings grouped in cards by subject, Essentials / All settings, a search across all settings, and the filters Changed from default and Needs a restart
- Units and allowed ranges shown, and checked when you save
Admin › Firmware
- New Firmware updates found online: the newer firmware the plugin found for your devices, with the download links and a warning. Wiki: WebUI Admin
- zigpy 2.4.1, bellows 1.2.1, zigpy-deconz 1.1.1
- ZLinky: EDF Zen Fixe "H PLEINE-CREUSE" option tarifaire
- Start: a device entry without IEEE no longer stops the plugin start (seen on a ZBDongle-E), and while the coordinator does not answer, the plugin restart is retried every 5 minutes instead of every second
- OTA: LEDVANCE updates now complete; a firmware found online is listed once
- Metering: plugs such as the Tuya TS011F are no longer asked for their unit and multiplier after every report
- Last Seen: a widget with an empty or unreadable Last Seen, or a device back from time-out, is refreshed again. If a quiet device still shows an old Last Seen, the new WidgetTouch debug category shows why
- Tools › Debug: Restore defaults replaces Turn all off, and keeps the plugin log on
- Device details: when the device was last seen and, for a battery device, when it last reported its battery
- Several plugin instances: every plugin thread name carries the hardware ID
- ReadAttributeChunk: 3 attributes per Read Attributes request instead of 10, if you never changed it
- The DomoticzDB stats / ZigpyTransport stats lines written every 5 minutes are off. They can be turned back on in Settings (All settings)
- resetOTAUpdate now applies at one start only, like the other one-time resets
- Plugin statistics: if you switch them off outside the WebUI, the plugin sends one last opt-out at the next start, as the WebUI switch already did. No new data is collected
- The transport statistics file is now written to Reports/Transport-stats.json. An old ReportsTransport-stats.json in the plugin folder can be deleted
- Admin › Plugin → Upgrade. It also installs the new zigpy libraries, so it can take several minutes
- When it says Done, click Restart now
- Reload the WebUI page to get the new screens
Full release notes: GitHub release stable9-9.1.010
Support the project
The plugin and its wiki are made on spare time, and any help is more than welcome: improving the wiki, testing and contributing to the plugin, or funding. Funding matters: Green Power support exists because one user's donation let me buy a Green Power switch and test it for real. Thank you!
- How to help: the Contribute and support section of the wiki home page, which also links every page named above
- Donate: PayPal — even a small amount helps to buy new devices to test and integrate
