Zigbee for Domoticz — stable9 9.1.010 (2026.16) is out
pipiche
Post by pipiche »
Two new features in this release, native Zigbee scenes and Green Power devices, and a new Settings page. The highlights:
Native Zigbee scenes (zigpy coordinators, off by default)
  • Turn them on in Settings › Available services › Features: Enable native Zigbee scenes (plugin restart needed)
  • A scene stores the state of the devices of a group in the devices themselves. One command recalls it on all of them at once, instead of one command per device
  • Management › Groups & Scenes: capture, test, re-capture and edit scenes, with an optional comment. A scene can be on only part of its group, and window coverings keep their position
  • Each group with scenes gets a Domoticz Selector Switch to recall them from Domoticz, scripts and timers
  • Groups: a new group can get the group id you choose, for example to match a remote set on a fixed group
How-to in the wiki: Zigbee scenes
Green Power devices (battery-free and low-energy switches)
  • Silicon Labs (EZSP) coordinators. Not available on Texas Instruments (Z-Stack) coordinators, which cannot receive Green Power frames. deCONZ (ConBee, RaspBee): not tested yet, reports welcome
  • Admin › Provisionning › Zigbee Green Power: pick the device type, Open for 4 minutes, and follow the pairing in a live log
  • Device types: On/Off switch, On/Off switch with dimming, 4-button switch (2 switches, 3 switches or single rocker), or Automatic. Tested with the Sunricher ZGP2801K2-DIM and the NodOn CWS-4-1-00
  • Every press reaches Domoticz, even when the switch already shows that state, so your events run at each press
  • Management › Devices: a details window for each Green Power device. One that got no widget can be given its type, or removed, from there
How-to in the wiki: Pair a Green Power device
Settings page
  • Settings grouped in cards by subject, Essentials / All settings, a search across all settings, and the filters Changed from default and Needs a restart
  • Units and allowed ranges shown, and checked when you save
Every setting in the wiki: WebUI Settings
Admin › Firmware
  • New Firmware updates found online: the newer firmware the plugin found for your devices, with the download links and a warning. Wiki: WebUI Admin
Also in 9.1.010
  • zigpy 2.4.1, bellows 1.2.1, zigpy-deconz 1.1.1
  • ZLinky: EDF Zen Fixe "H PLEINE-CREUSE" option tarifaire
  • Start: a device entry without IEEE no longer stops the plugin start (seen on a ZBDongle-E), and while the coordinator does not answer, the plugin restart is retried every 5 minutes instead of every second
  • OTA: LEDVANCE updates now complete; a firmware found online is listed once
  • Metering: plugs such as the Tuya TS011F are no longer asked for their unit and multiplier after every report
  • Last Seen: a widget with an empty or unreadable Last Seen, or a device back from time-out, is refreshed again. If a quiet device still shows an old Last Seen, the new WidgetTouch debug category shows why
  • Tools › Debug: Restore defaults replaces Turn all off, and keeps the plugin log on
  • Device details: when the device was last seen and, for a battery device, when it last reported its battery
  • Several plugin instances: every plugin thread name carries the hardware ID
Default changes — check them if you rely on the old ones
  • ReadAttributeChunk: 3 attributes per Read Attributes request instead of 10, if you never changed it
  • The DomoticzDB stats / ZigpyTransport stats lines written every 5 minutes are off. They can be turned back on in Settings (All settings)
  • resetOTAUpdate now applies at one start only, like the other one-time resets
  • Plugin statistics: if you switch them off outside the WebUI, the plugin sends one last opt-out at the next start, as the WebUI switch already did. No new data is collected
  • The transport statistics file is now written to Reports/Transport-stats.json. An old ReportsTransport-stats.json in the plugin folder can be deleted
Upgrade — from the WebUI, as usual
  1. Admin › Plugin → Upgrade. It also installs the new zigpy libraries, so it can take several minutes
  2. When it says Done, click Restart now
  3. Reload the WebUI page to get the new screens
Domoticz 2026.3 is the recommended version. Details and troubleshooting: Plugin update
Full release notes: GitHub release stable9-9.1.010
Support the project
The plugin and its wiki are made on spare time, and any help is more than welcome: improving the wiki, testing and contributing to the plugin, or funding. Funding matters: Green Power support exists because one user's donation let me buy a Green Power switch and test it for real. Thank you!
  • How to help: the Contribute and support section of the wiki home page, which also links every page named above
  • Donate: PayPal — even a small amount helps to buy new devices to test and integrate
Feedback welcome in this thread.
WouterO
Re: Zigbee for Domoticz — stable9 9.1.010 (2026.16) is out
Post by WouterO »
Hi pipiche,
Thanks for this update. It’s up and running. After the Web UI update, the new plugin was running fine, but the new Web UI wasn’t showing. But the cli way of updating (git pull and pip) repaired this problem. I’m up to date again 🙂
pipiche
Post by pipiche »
Enjoy the Native scenes , this is very simple to use
Rik60
Domoticz version: 2026.3
Post by Rik60 »
Updated from 9.1.009 to 9.1.010. No problems. Ui was showing.
