Log entry twice every 15 minutes: "Status: EventSystem: reset all device statuses..." Topic is solved
andrehj
Domoticz version: 2026.4
Post by andrehj »
My Domoticz log is flooded with the lines below, every 15 minutes two status lines are created which say that all device statuses are reset:
2026-10-24 06:00:02.508  Status: EventSystem: reset all device statuses...
2026-10-24 06:00:03.176  Status: EventSystem: reset all device statuses...
2026-10-24 06:15:02.577  Status: EventSystem: reset all device statuses...
2026-10-24 06:15:03.191  Status: EventSystem: reset all device statuses...
2026-10-24 06:30:02.241  Status: EventSystem: reset all device statuses...
2026-10-24 06:30:02.894  Status: EventSystem: reset all device statuses...
2026-10-24 06:45:02.804  Status: EventSystem: reset all device statuses...
2026-10-24 06:45:03.394  Status: EventSystem: reset all device statuses...
2026-10-24 07:00:02.939  Status: EventSystem: reset all device statuses...
2026-10-24 07:00:03.537  Status: EventSystem: reset all device statuses...
2026-10-24 07:15:01.055  Status: EventSystem: reset all device statuses...
2026-10-24 07:15:03.202  Status: EventSystem: reset all device statuses...
2026-10-24 07:30:03.192  Status: EventSystem: reset all device statuses...
2026-10-24 07:30:03.824  Status: EventSystem: reset all device statuses...
2026-10-24 07:45:02.911  Status: EventSystem: reset all device statuses...
2026-10-24 07:45:03.511  Status: EventSystem: reset all device statuses...
2026-10-24 08:00:02.755  Status: EventSystem: reset all device statuses...
2026-10-24 08:00:03.348  Status: EventSystem: reset all device statuses...
2026-10-24 08:15:01.114  Status: EventSystem: reset all device statuses...
2026-10-24 08:15:03.150  Status: EventSystem: reset all device statuses...
2026-10-24 08:30:03.210  Status: EventSystem: reset all device statuses...
2026-10-24 08:30:03.836  Status: EventSystem: reset all device statuses...
2026-10-24 08:45:02.846  Status: EventSystem: reset all device statuses...
2026-10-24 08:45:03.514  Status: EventSystem: reset all device statuses...
2026-10-24 09:00:01.867  Status: EventSystem: reset all device statuses...
2026-10-24 09:00:03.340  Status: EventSystem: reset all device statuses...
2026-10-24 09:15:03.287  Status: EventSystem: reset all device statuses...
2026-10-24 09:15:03.935  Status: EventSystem: reset all device statuses...
2026-10-24 09:30:03.067  Status: EventSystem: reset all device statuses...
2026-10-24 09:30:03.666  Status: EventSystem: reset all device statuses...
2026-10-24 09:45:02.790  Status: EventSystem: reset all device statuses...
2026-10-24 09:45:03.475  Status: EventSystem: reset all device statuses...
2026-10-24 10:00:02.397  Status: EventSystem: reset all device statuses...
2026-10-24 10:00:03.216  Status: EventSystem: reset all device statuses...
I think this has been going on for months already.
Is this normal behavior?
If no, what could be the cause?
Re: Log entry twice every 15 minutes: "Status: EventSystem: reset all device statuses..."
This is not normal, it normally happens only 1 time a day at Midnight.
Check your dzvents scripts if something is triggered every 15 minutes.
andrehj
Post by andrehj »
Thanks @waltervl! I thought I did not have a script starting every 15 minutes, but after a better search, I found there is one, and indeed this script is causing the issues.
Now trying to solve the puzzle with some help from Gemini...
andrehj
Post by andrehj »
Found the culprit!
The command
dz.devices(wl_rain_idx).setIcon(iconNumber)
was causing Domoticz to reset all device statuses. More details in the topic about the script "Weerlive": viewtopic.php?p=336181#p336181
gizmocuz
Post by gizmocuz »
Thanks for tracking this down. setIcon (like a rename or saving the device edit dialog) made Domoticz reload the state of every device for the event system, which logged "reset all device statuses" each time. It now reloads only the device that changed, so a script calling setIcon no longer triggers this. The fix will be in the next beta.
andrehj
Post by andrehj »
Thanks. That is good news. I usually do not install beta's, so I will look forward to this fix in the next non-beta release.
gizmocuz
Post by gizmocuz »
So, the beta contains fixes/security updates and stability fixes.
I guess upgrading to it would be benifitial.
