Change in Text/Alert Sensor (beta)
gizmocuz
Post by gizmocuz »
In beta 17823 I removed the text device 48x48 icon and added better support for HTML rendering.
The text contains of the above HTML is:
textsensor.txt
(3.79 KiB) Downloaded 198 times
I think the Icon was not needed, a Alert sensor does support a icon.
janpep
Domoticz version: v2026.3
Re: Change in Text/Alert Sensor (beta
Post by janpep »
gizmocuz wrote: Monday 27 April 2026 11:01 I think the Icon was not needed, a Alert sensor does support a icon.
Indeed. Thank you. Looks very good.
I already hide the icon for a long time with small CSS addition, because it only took place and had no additional value or meaning.
Dz on Ubuntu VM on Proxmox behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
RonkA
Domoticz version: 2025.1
Re: Change in Text/Alert Sensor (beta)
Post by RonkA »
Excellent!! this is very welcome.
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
janpep
Post by janpep »
OOPS...
Installed latest beta and realized, that I do have some custom icons for text devices with a meaning based on content.
I completely agree that the standard text icon adds nothing.
But for example, for rain information based on the forecast, I use an icon with rain or (by script) switch automatically to one without rain.
In the end, it would be most flexible if you could turn it on/off per device.
I also noticed that line breaks have disappeared in some devices. I need to look into that further.
janpep
Post by janpep »
janpep wrote: Wednesday 29 April 2026 12:30 I also noticed that line breaks have disappeared in some devices. I need to look into that further.
Found out that I used \n in several places. Replaced now by <br>
gizmocuz
Post by gizmocuz »
@janpep, is a alert sensor not what you want? This has an icon
janpep
Post by janpep »
gizmocuz wrote: Wednesday 29 April 2026 20:08 @janpep, is a alert sensor not what you want? This has an icon
I have a few devices with no meaning for alerting, but where the icon does have a meaning, give additional information or faster recognition between the other devices.
e.g. I have one for the waste calendar with a rotating icon for a brown, blue, or green trash can. I have one for text device with Rain or No rain and another with other symbols for the weather forecast. Also on the Dashboard tab the icon of the text device gives the oppertunity to go directoy to the log.
So, although I initially thought it was a good idea, my enthusiasm is waning a bit. When it is purely and simply the standard text icon, I think it is not needed.
May be the fastest is to only remove when it is the standard icon as I did?
For the other text devices, where I have replaced it with a custom icon, I believe it serves a purpose and I would like to keep it/get it back.
More work, but as stated, if EVERY device had the Icon on/off option, you would be most flexible. Then users could decide for themselves. Some will find the usefulness of a counter that is always fixed redundant, while others might want to keep it for recognition purposes.
Gingerpale
Domoticz version: 2026.1
Post by Gingerpale »
I have similar issue like Janpep: How to handle text sensors with a custom icon which do serve a purpose for me?
How can I get it back? Can I use the new html style for that? If yes, how?
Currently it looks weird that if custom icon 48x48 is removed, I still can select one which doesn't show. That doesn't seem consistent, unless I miss something else?
In any way, the text sensor with enriched html looks really cool.
Text sensor - custom icon.jpg (33.59 KiB) Viewed 39436 times
Text sensor - custom icon not displayed.jpg (12.81 KiB) Viewed 39436 times
Rpi4B,RFX433e,PiFace2, LCD, Hue bridge, Alexa (+TTS), HA-Bridge, Sonoff NSPanel, Sonoff RF (+IR) bridge, Nefit CV, Tasmota/MQTT, Enphase Solar, Smartmeter, Alarm I/F, H13726B Weather Station, CM180 Energy meter, Sonoff, KaKu, Tuya, Gledopto, AriLux,...
claude2666
Post by claude2666 »
HI,
In the latest betas (17920), for a text widget, no icon is displayed. Mine are all set to default icons. And even if I select a specific Icon, it is not displayed. This happens both in the utility tab and the new dynamic dashboard. And this for all my text sensors, with default or custom icon
With default icon:
And with specific icon has the same result, no icon in the widget. see first screenshot
janpep
Post by janpep »
I would like to hear what the plan is or will be, so that I am not waiting for something that might never come back.
If the policy is or becomes that the icon disappears entirely, I am certainly not happy with that. I will have to come up with a solution for that, e.g. by using Alert device (even where there is no alert and text is more appropriate). Than it is just for being able to show (and change) the icon with a text.
I would prefer to see the icon remains visible at least when an icon other than the 'Default' has been chosen, or that there is a choice for the user in some other way. After all, if someone has chosen a different icon, there is certainly a reason for it. A sufficient reason not to simply remove it.
Perhaps a 'NO-ICON' option in the icon selection list can give users an easy and flexible way to select an icon of their choice OR to remove the icon for that device. Then it can be used consistently throughout the entire system and is not necessarily limited to text devices.
gizmocuz
Post by gizmocuz »
I will look at into the no icon option.
janpep
Post by janpep »
gizmocuz wrote: Sunday 03 May 2026 20:37 I will look at into the no icon option.
I think that would be great. Flexible yet consistent.
sebitop
Post by sebitop »
Hi Gizmo and everyone,
I’m experiencing the same issue.
Certain text devices are much more intuitive with an icon; for instance, I use a text box to track remaining 'color days' for my French electricity provider.
Removing icons across all text devices makes the dashboard feel less visual and harder to read at a glance.
Giving users a 'no icon' toggle while keeping the option to use one is the perfect middle ground.
seb
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
gizmocuz
Post by gizmocuz »
Changed in beta 17921
Default icon is visible, but you can edit the text device and specify to hide the icon
Gingerpale
I've just tried latest beta and I can confirm it works. Many thanks for fixing it again!
janpep
Post by janpep »
gizmocuz wrote: Monday 04 May 2026 7:33 Default icon is visible, but you can edit the text device and specify to hide the icon
Tested. Very nice solution to be able to turn it off for a few, but not for all text devices. Thanks again!
