Domoticz 2026.v1 stable running in docker-container.
I just noticed that I can't read any logs of my devices. Is there a workaround?
no log readings possible v2026v1 stable
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2026.3
Re: no log readings possible v2026v1 stable
What did you do? As this is normal functionality...
Did you change theme?
Incorrect docker compose yml?
BartSr
Walter, this happened out of the blue. Every device I pushed the log button does not react.
And now all works again as normal.
Kind of black magic......
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
