no log readings possible v2026v1 stable
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
BartSr
Domoticz version: V2024.7
Post by BartSr »
Domoticz 2026.v1 stable running in docker-container.
I just noticed that I can't read any logs of my devices. Is there a workaround?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2026.3
Re: no log readings possible v2026v1 stable
What did you do? As this is normal functionality...
Did you change theme?
Incorrect docker compose yml?
BartSr
Post by BartSr »
Walter, this happened out of the blue. Every device I pushed the log button does not react.
And now all works again as normal.
Kind of black magic......
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
