Reading TE923 Weather Station
PE1IAA
Post by PE1IAA »
Hello readers,
It seems that TE923 USB Compatible Weather Station is no longer in the hardware list.
Who can i now connect my TE923 to domoticz.
I can read of cours also with RFXCOM - RFXtrx433 USB 433.92MHz Transceiver but than i cannot get the data
from my weatherstation like inside temperature and Barometer values.
Who can help me,
Regards Harry de PE1IAA
Domoticz version: 2025.1
Re: Reading TE923 Weather Station
I still have it in my hardware list in 2025.2 stable. And it does niet seems to be removed from latest beta.
On what type of environment are you running?
gizmocuz
Post by gizmocuz »
If you own a RFXTrx433, I would suggest to have a look at a 433Mhz Temp+Hum+Baro meter, or buy a Zigbee THB sensor.
Both are not expensive.
If it is still visible under the supported hardware dropdown list, it should still be supported.
The TE923 (as well as a certain Voltcraft CO2 sensor) uses a special LIBUSB driver.
I noticed you have a PWS weather station page... so you should be able to get this data as well in Domoticz?
'73!
PE1IAA
Post by PE1IAA »
Hallo Waltervl and gizmocuz,
I run domoticz on window 10 machine as my Rpb4+ does not work anymore with this software 2025.2
I have to update my machine but weewx is also no longer running than.
Ihave the following list in hardware. (see enclosure).
73's
Schermafbeelding 2026-01-28 172115.png (50.07 KiB) Viewed 28 times
