When changing temp sensor most history lost. Bug?
BartSr
Domoticz version: V2024.7
Post by BartSr »
I had to change a temp device. I followed the instructions to keep all history values but I ended with only history of this year. Should it be a bug or is there another way to keep history of many years?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: When changing temp sensor most history lost. Bug?
Could be an issue in your database table with the old values.
You can check with SQLite DB browser on a backup before the replacement what could be the issue.
BartSr
Post by BartSr »
What might be an issue Walter? Where/ what to check?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
I dont know, some inconsistency somewhere.
BartSr
Post by BartSr »
Walter, do you know where to find thd routine in the source? To me ik looks like an SQL error but I don't have the skills to figure out where tk look kn the sourcecode
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
It is not a normal error as it does normally do all history data. So something probably is wrong in your data that gives an hickup.
I also have no idea where the replacement function including SQL query is. But better look at your database first.
