When changing temp sensor most history lost. Bug?
BartSr
- Domoticz version: V2024.7
I had to change a temp device. I followed the instructions to keep all history values but I ended with only history of this year. Should it be a bug or is there another way to keep history of many years?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Domoticz version: 2025.1
Re: When changing temp sensor most history lost. Bug?
Could be an issue in your database table with the old values.
You can check with SQLite DB browser on a backup before the replacement what could be the issue.
BartSr
What might be an issue Walter? Where/ what to check?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
I dont know, some inconsistency somewhere.
BartSr
Walter, do you know where to find thd routine in the source? To me ik looks like an SQL error but I don't have the skills to figure out where tk look kn the sourcecode
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
It is not a normal error as it does normally do all history data. So something probably is wrong in your data that gives an hickup.
I also have no idea where the replacement function including SQL query is. But better look at your database first.
