Xiaomi Gateway : no device detected since new install
Jeremob
Post by Jeremob »
Hello !
I have update my domoticz to the last version (running on RPI4 with buster)
Of course, many issues, like Openssl 3, etc ...
So I decide to build quickly a new Domoticz (new RPI5 with last OS, new domoticz install), and restore the domoticz.db previously backuped before the failed update (ouf !)
Domoticz is online, RFX is working, all my devices there. But no update from the Xiaomi gateway. The IP of the gateway still the same, also the password entered again, and no Xiaomi devices appears / no update on current Xiaomi devices ...
The 9898 still opened
Capture d'écran 2025-10-17 185456.png (14.61 KiB) Viewed 76 times
Any ideas why ?
Thanks !
StratosHF
Domoticz version: 2025.1
Re: Xiaomi Gateway : no device detected since new install
Post by StratosHF »
Me too!
My old Raspberry Pi that has been rock steady for years can't update to 2025.2 due to SSL v3. I decided to do a full rebuild using "Raspberry Pi OS (Legacy) Lite 32-bit". Domoticz was installed and ran OK until I restored my database. Domoticz would run for 20 seconds and then crash. I disabled all the hardware in the DB and one by one added them back, Pi system, RFXcom, 1wire, all OK until I added the Xiaomi gateway.
Jeremob
Post by Jeremob »
Finally, the solution was to add a new device (the same!), and remove the old one.
Then, replace all devices one by one to keep the history
Weerd !
StratosHF
Post by StratosHF »
My issue turned out to be a different problem but I want to share the resolution in case anyone else sees this. In my haste to get going I hadn't configured my Raspberry Pi's IP address properly, I had set the fixed IP with
sudo nmcli c mod "Wired connection 1" ipv4.addresses 192.168.1.100/24
but I didn't set "ipv4.gateway", "ipv4.dns", "ipv4.method manual" and I guess this was crashing the Xiaomi gateway plugin when it tried to talk to the gateway over the network. Once I had set these the gateway was OK. One of my sensors was lost but restored by adding it via the "Xiaomi Home" app on my phone.
