Error: Invalid Number Value: '%' for device idx: '%' Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
teo1966
Domoticz version: 2025.1
Post by teo1966 »
Version: 2025.1 whit snap container
Platform: PI 3B
Plugin/Hardware: Zwave-js-ui: 10.8.0 / Zwave-js: 15.8.0 and Dashticz V3.18 master XTEND-plugin 1.01
Description:
I'm getting this error:
Any ideas?
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
teo1966
Re: Error: Invalid Number Value: '%' for device idx: '%'
Post by teo1966 »
I don't know if it's related to this problem. The only devices with RFXMeter do show up in utility, but the Lacrosse TX3 and Depressure and the rest don't show up in temperature or switches.
Screenshot 2025-07-10 at 11-29-39 Domoticz.jpg (218.99 KiB) Viewed 2423 times
Release: 11
Codename: bullseye
teo1966 wrote: Thursday 10 July 2025 11:24
In what context? Is there more in the log around this error?
teo1966 wrote: Thursday 10 July 2025 11:36 I don't know if it's related to this problem. The only devices with RFXMeter do show up in utility, but the Lacrosse TX3 and Depressure and the rest don't show up in temperature or switches.
In menu Setup - Users do you have devices assigned to the user (admin?) you are logging into Domoticz? If admin then remove all those shared devices. See also the Note on this subject in the wiki:
https://wiki.domoticz.com/User_Management#Set_Devices
Note: It is advised not to set selected devices for an admin user as the rest of the devices will become invisible.
