Error: Invalid Number Value: '%' for device idx: '%' Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
teo1966
- Domoticz version: 2025.1
Version: 2025.1 whit snap container
Platform: PI 3B
Plugin/Hardware: Zwave-js-ui: 10.8.0 / Zwave-js: 15.8.0 and Dashticz V3.18 master XTEND-plugin 1.01
Description:
I'm getting this error:
Any ideas?
Platform: PI 3B
Description:
Any ideas?
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
teo1966
Re: Error: Invalid Number Value: '%' for device idx: '%'
I don't know if it's related to this problem. The only devices with RFXMeter do show up in utility, but the Lacrosse TX3 and Depressure and the rest don't show up in temperature or switches.
Release: 11
Codename: bullseye
Release: 11
Codename: bullseye
- Domoticz version: 2026.3
In what context? Is there more in the log around this error?teo1966 wrote: Thursday 10 July 2025 11:24
In menu Setup - Users do you have devices assigned to the user (admin?) you are logging into Domoticz? If admin then remove all those shared devices. See also the Note on this subject in the wiki:teo1966 wrote: Thursday 10 July 2025 11:36 I don't know if it's related to this problem. The only devices with RFXMeter do show up in utility, but the Lacrosse TX3 and Depressure and the rest don't show up in temperature or switches.
https://wiki.domoticz.com/User_Management#Set_Devices
Note: It is advised not to set selected devices for an admin user as the rest of the devices will become invisible.
PeJeWe
- Domoticz version: Latest
i also get the error: Error: Invalid Number sValue: '%' for device idx: '%'waltervl wrote: Thursday 10 July 2025 12:27In menu Setup - Users do you have devices assigned to the user (admin?) you are logging into Domoticz? If admin then remove all those shared devices. See also the Note on this subject in the wiki:teo1966 wrote: Thursday 10 July 2025 11:36 I don't know if it's related to this problem. The only devices with RFXMeter do show up in utility, but the Lacrosse TX3 and Depressure and the rest don't show up in temperature or switches.
i have no selected devices signed to the admin account.
i get the error when i call: http://domoticzIP:port/json.htm?type=command¶m=getdevices&filter=all&used=true
willemd
I only get this error if a plugin creates a P1 device and no value is uploaded to the device yet and then the device is queried for example via the user interface. Immediately after the first value update by the plugin the error disappears and everything functions normally. So it is a small bug in the Domoticz plugin framework.
Is this the same as your case? Do tou have any P1 devices from a plugin that are still without a value?
PeJeWe
I do not have any problem with my p1 sensor.willemd wrote: Saturday 16 May 2026 20:28 I only get this error if a plugin creates a P1 device and no value is uploaded to the device yet and then the device is queried for example via the user interface. Immediately after the first value update by the plugin the error disappears and everything functions normally. So it is a small bug in the Domoticz plugin framework.
I only have that error when i ask domoticz for a complete json device list.
willemd
You can try different filters to narrow down the problem.
PeJeWe
I have tried to shut off hardware things like mqtt broker, mqtt gateway, RFXCOM, internal running dzVents scripts, external python scripts, still getting the error randomly.
Has anyone still any ideas to narrow it down?
When I try to debug sql domoticz crashes.
And sometimes when I connect to the webgui domoticz reports having no sensors connected. And when I select another tab they re appear.
- jvdz
- Domoticz version: 4.107
Have you checked the actual domoticz.db with SQLite Express to see if there are any devices in the devicestatus table that have a "wrong" value in the sValue column?
willemd
Did you try narrowing it down as suggested by adjusting the filter in your statement ?PeJeWe wrote: Thursday 28 May 2026 15:51 I have tried to shut off hardware things like mqtt broker, mqtt gateway, RFXCOM, internal running dzVents scripts, external python scripts, still getting the error randomly.
According to the wiki you can use the following filters
light
weather
temp
utility
wind
rain
uv
baro
zwavealarms
PeJeWe
I have checkt it according your list and the following generates this error : utility and zwavealarms.willemd wrote: Thursday 28 May 2026 19:15Did you try narrowing it down as suggested by adjusting the filter in your statement ?PeJeWe wrote: Thursday 28 May 2026 15:51 I have tried to shut off hardware things like mqtt broker, mqtt gateway, RFXCOM, internal running dzVents scripts, external python scripts, still getting the error randomly.
light
weather
temp
utility
wind
rain
uv
baro
zwavealarms
The lists are to long to present here.
how to narrow it down now?
willemd
Check the values of the devices in those sublists, either by individual json queries or by using sql.
PeJeWe
I have found the 2 conflicting sensors.
one was a ghost sensor that was not in use anymore, and they other had bad data in it.
when this was deleted and restored the error dus not appear anymore.
thanks for the great help
