Hey all (and pipiche),
I just bought the new Sonoff SNZB-02WD with IP65 rating for outside use. I can confirm that this new Temp and rel.hum. sensor pairs and works perfectly with the Zigbee for Domoticz plugin i.c.w. the Sonoff dongle E.
Just to let you know. Maybe more of you are looking for monitoring outside.
Sonoff Temp sensor for outside Topic is solved
Re: Sonoff Temp sensor for outside
great and thanks for sharing.
Kindly share on MP the device details from the plugin, so I can have a look
WouterO
Hi pipiche,
Attached is the export.json file per request.
- exportjson.txt
- (7.96 KiB) Downloaded 290 times
- gizmocuz
It also works great with Zigbee2MQTT
(As well as the SNZB-02LD)
Thanks mate, will make it supported this eveningWouterO wrote: Wednesday 25 June 2025 11:10 Hi pipiche,
