Sonoff Temp sensor for outside Topic is solved
WouterO
Post by WouterO »
Hey all (and pipiche),
I just bought the new Sonoff SNZB-02WD with IP65 rating for outside use. I can confirm that this new Temp and rel.hum. sensor pairs and works perfectly with the Zigbee for Domoticz plugin i.c.w. the Sonoff dongle E.
Just to let you know. Maybe more of you are looking for monitoring outside.
pipiche
Re: Sonoff Temp sensor for outside
Post by pipiche »
great and thanks for sharing.
Kindly share on MP the device details from the plugin, so I can have a look
WouterO
Post by WouterO »
Hi pipiche,
Attached is the export.json file per request.
exportjson.txt
(7.96 KiB) Downloaded 290 times
gizmocuz
Post by gizmocuz »
It also works great with Zigbee2MQTT
(As well as the SNZB-02LD)
pipiche
Post by pipiche »
WouterO wrote: Wednesday 25 June 2025 11:10 Hi pipiche,
Thanks mate, will make it supported this evening ;-)
