[ 2025.1]Melcloud2Domoticz .sh script not working anymore Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
ricvee
Domoticz version: Stable
Post by ricvee »
Where can I find Version: 2024.7 for a Raspberry pi? I cannot find it on https://github.com/domoticz/domoticz/releases
I need to downgrade because the control with a .sh script for my Mitsubishi Hetpump with Melcloud is not working as it should.
Perhaps somebody can put the right releases back on github?
There are for version 2024.7 only 3 Assets instead of 7
Thanks,
Ric
ricvee
Re: Melcloud2Domoticz not working properly in 2025.1
Post by ricvee »
I can no longer write things back from Domoticz to Melcloud.
This is the script:
melcloud2domoticz_2025_2.txt
(29.81 KiB) Downloaded 38 times
jvdz
Domoticz version: 4.107
Re: Domoticz version 2025.1 released
Post by jvdz »
Just use your backup which should have been created during the upgrade process. ( and honestly I always make a full manual backup aswell before any major change)
ricvee
Post by ricvee »
Sure!
I restored it and now the script is working fine again.
Thank you!
Domoticz version: 2025.1
Re: [ 2025.1] .sh script not working anymore
ricvee wrote: Thursday 08 May 2025 17:38 Where can I find Version: 2024.7 for a Raspberry pi? I cannot find it on https://github.com/domoticz/domoticz/releases
Thanks,
Ric
Does your .sh script uses Domoticz API calls to update Domoticz devices? Then you probably need to change those. See wiki https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
ricvee wrote: Thursday 08 May 2025 17:51 I can no longer write things back from Domoticz to Melcloud.
This is the script:
I merged the 2 topics you posted in.
In the script I see for example
http://$SERVERIP:$PORT/json.htm?type=devices&rid=$IDXHeatpumpStatus
This should be
http://$SERVERIP:$PORT/json.htm?type=command&param=getdevices&rid=$IDXHeatpumpStatus
ricvee
Re: [ 2025.1]Melcloud2Domoticz .sh script not working anymore
Post by ricvee »
Thanks waltervi!
I will change the script, and let you know here.
Should the new notation also work in 2024.7 ?(for testing first before I upgrade again to 2025.1)
Yes, new API calls also work in 2024.7. Those are already available from even older 2023.2.
In 2024.7 you should now have warnings in the log you are using deprecated RType calls. If you change the script to use the new API calls you wont see those messages anymore.
ricvee
Post by ricvee »
Everything is working like a charm again!
And I upgraded again to 2025.1.
Thanks again, for the help.
