Where can I find Version: 2024.7 for a Raspberry pi? I cannot find it on https://github.com/domoticz/domoticz/releases
I need to downgrade because the control with a .sh script for my Mitsubishi Hetpump with Melcloud is not working as it should.
Perhaps somebody can put the right releases back on github?
There are for version 2024.7 only 3 Assets instead of 7
Thanks,
Ric
[ 2025.1]Melcloud2Domoticz .sh script not working anymore Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: Stable
Re: Melcloud2Domoticz not working properly in 2025.1
I can no longer write things back from Domoticz to Melcloud.
This is the script:
This is the script:
- melcloud2domoticz_2025_2.txt
- (29.81 KiB) Downloaded 32 times
- jvdz
- Domoticz version: 4.107
Re: Domoticz version 2025.1 released
Just use your backup which should have been created during the upgrade process. ( and honestly I always make a full manual backup aswell before any major change)
Sure!
I restored it and now the script is working fine again.
Thank you!
Thank you!
- Domoticz version: 2024.7
Re: [ 2025.1] .sh script not working anymore
Does your .sh script uses Domoticz API calls to update Domoticz devices? Then you probably need to change those. See wiki https://wiki.domoticz.com/Domoticz_API/ ... and_newer)ricvee wrote: ↑Thursday 08 May 2025 17:38 Where can I find Version: 2024.7 for a Raspberry pi? I cannot find it on https://github.com/domoticz/domoticz/releases
Thanks,
Ric
I merged the 2 topics you posted in.
In the script I see for example
http://$SERVERIP:$PORT/json.htm?type=devices&rid=$IDXHeatpumpStatus
http://$SERVERIP:$PORT/json.htm?type=command¶m=getdevices&rid=$IDXHeatpumpStatus
Re: [ 2025.1]Melcloud2Domoticz .sh script not working anymore
Thanks waltervi!
I will change the script, and let you know here.
Should the new notation also work in 2024.7 ?(for testing first before I upgrade again to 2025.1)
Yes, new API calls also work in 2024.7. Those are already available from even older 2023.2.
In 2024.7 you should now have warnings in the log you are using deprecated RType calls. If you change the script to use the new API calls you wont see those messages anymore.
Everything is working like a charm again!
And I upgraded again to 2025.1.
Thanks again, for the help.
