Door contact + MQTT -> "On action" & "Off action" do not execute Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
fdemees
Domoticz version: 2024.7
Post by fdemees »
Hello, dear Community,
Version: Version 2024.7 (July 13th 2024)
Platform: RPi3B+, Debian 11.11
Plugin/Hardware: MQTT Client Gateway with LAN interface, other unrelated
Description:
I have set up a door sensor, based on a esp8266 Wemos, running the most recent version of Tasmota.
A Domoticz switch device is created from the Dummy hardware device, as usual.
The communication between the door sensor and Domoticz is done with MQTT and is reliable.
I want to use this door sensor in order to action an alarm system reachable via https.
2025-04-10 15_05_20-Domoticz — Mozilla Firefox.png (22.9 KiB) Viewed 2197 times
I have discovered that the switch configured as "Door sensor" triggers the notifications on every status change, but does not trigger the "On action" or "Off action".
If I set the switch as an on/off standard switch (with a bulb as default icon) instead of a Sensor, when I change the status via the GUI the On and Off actions are successfully called, but when the trigger comes from MQTT, again no action is performed.
(Please note that I have tried both https:// and script:// in Actions, and neither method works)
Is this a defect, or a feature, is there a workaround ?
Thank you for your bright ideas :)
Domoticz on Rpi 3B+, ZigbeeforDomoticz, Sonoff Zigbee coordinator, several Sonoff/ESPEasy/Tasmota, IPX800, several Zigbee things, Ksenia Lares
Domoticz version: 2025.1
Re: Door contact + MQTT -> "On action" & "Off action" do not execute
What is the MQTT message that the switch sends to Domoticz/in?
It should not contain command "udevice"
See also the wiki https://wiki.domoticz.com/MQTT#Sending_a_Switch_Command
fdemees
Post by fdemees »
Hello @waltervl
The message sent by the Tasmota device (door sensor) is:
(door opened)
domoticz/in = {"idx":203,"nvalue":1,"svalue":"","Battery":100,"RSSI":7}
(door closed)
domoticz/in = {"idx":203,"nvalue":0,"svalue":"","Battery":100,"RSSI":7}
What I did (and I may be wrong)
This is the esp8266 module I had purchased years ago: (https://www.banggood.com/Geekcreit-ESP8 ... 36275.html) (https://templates.blakadder.com/geekcreit_10A.html)
2025-04-12 11_03_01-.jpg (17.02 KiB) Viewed 2129 times
I have uploaded the most recent version of Tasmota 14.5.0
and configured the module as shown:
2025-04-12 10_47_30-Wemos1 Module — Mozilla Firefox.png (11.51 KiB) Viewed 2129 times
The module is designed in factory with: GPIO4=output relay , GPIO5=input sensor via optocoupler.
As for many esp8266, GPIO2 drives the status LED on board.
I have thus configured GPIO5 as Switch1 in Tasmota device configuration.
Any change on the door switch generates MQTT messages like
tele/wemos1/SENSOR = {"Time":"2025-04-12T09:53:05","Switch1":"OFF"}
but these messages are not addressed to the Domoticz MQTT queue.
So I have used the feature of Tasmota, linking the input contact to the output #1 (here the blue LED on GPIO2 declared as Relay1), and the LED status change is reported to domoticz/in
Now I understand why Domoticz would not trigger the actions, because it receives a reported status change of a relay. (and not a switchcmd)
I have just discovered your other reply on a similar topic viewtopic.php?t=40656
I will now study how to make scripts within Tasmota.
Thank you a lot for the suggestions.
fdemees
Post by fdemees »
Dear Walter,
I have typed the following commands on the Tasmota console: (as suggested here viewtopic.php?t=40656)
SwitchMode1 1
SwitchTopic1 0
Rule1 on Switch1#state=1 do Publish domoticz/in {"command": "switchlight", "idx": 203, "switchcmd": "On" } endon on Switch1#state=0 do Publish domoticz/in {"command": "switchlight", "idx": 203, "switchcmd": "Off" } endon
Rule1 1
it is a success. Great !
Nice that it works now!
