tendances value in the dzvent script
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
hi,
i have a rfx meter counter. Is it possible to get the value 349 tendance water in the dzvents script ?
Pierrotori
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2025.1
Re: tendances value in the dzvent script
I believe it is calculated by the highcharts graph module on the webgui part. So not available in dzvents.
You could ofcourse have dzvents calculate a trend based on the values in the database.
pierrotori
if i would like to use the function in dzvents to calculate a trend bases, i suppose i use a sqlite function, is it correct ?
but by default sqlite is not installed
No, sqlite is never needed to do dzvents actions.
You probably need an Domoticz json API param=graph call to get the history data https://wiki.domoticz.com/Domoticz_API/ ... 7s#History
From that data you can calculate the trend with dzvents/lua. There will probably be Lua functions for that.
pierrotori
very good, thanks a lot i continue to update the dzvents script
pierrotori
i try this
http://xxx.xxx.xx.x:8080/json.htm?groupby=month&idx=625&param=graph&sensor=counter&type=command
, but no tendance water in the result of http
As said before, the web graph module highcharts that Domoticz is using is calculating the tendency itself. As input it is using the same raw data from the API calls you now used.
So you have to calculate the tendency yourself with dzvents the same way as the highcharts module is doing.
pierrotori
i found the formule
n = len(days)
sum_x = sum(days)
sum_y = sum(water)
sum_xx = sum(days * days)
sum_xy = sum(days * water)
# Formules pour la pente (slope) et l'ordonnée à l'origine (intercept)
# slope = (n∑(xy)−∑x∑y)/(n∑(x^2)-∑(x)^2)
slope = (n * sum_xy - sum_x * sum_y) / (n * sum_xx - sum_x ^2)
# intercept = (∑y - slope * ∑x) /n
intercept = (sum_y - slope * sum_x) / n
tendance = slope * days + intercept
