Domotiz not ready for latest Debian?!? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
/domoticz/domoticz: /lib/x86_64-linux-gnu/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by /home/domoticz)
come on...
Did a fresh install, latest debian (12) on proxmox VM NUC, but now you teling me domoticz needs older OS?
Installed OPENSSL 1.1, but still no good. [edit: apparently not]
Please update wiki and tell us which Ubuntu/Debian version to use
come on...
- Domoticz version: 2025.1
Re: Domotiz not ready for latest Debian?!?
It works but you need to install libssl1.1 as that is replaced by libssl3
There are other topics about this, a little search will find these. Or use the docker environment to get rid of software requirements.
Re: Domotiz not ready for latest Debian?!? -libssl1.1
no thank you, I'm just new in the proxmox matter, and there is not enough will to struglle through Docker USB matter. Or use the docker environment to get rid of software requirements.
attempts to install 1.1: no luck
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
--2025-01-21 18:00:43-- http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
Resolving security.debian.org (security.debian.org)... 151.101.66.132, 151.101.194.132, 151.101.130.132, ...
Connecting to security.debian.org (security.debian.org)|151.101.66.132|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2025-01-21 18:00:43 ERROR 404: Not Found.
wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo dpkg -i libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
sudo dpkg -i synergy_1.14.3-stable.218fa800_ubuntu21_amd64.deb
--2025-01-21 18:03:11-- http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
Resolving security.ubuntu.com (security.ubuntu.com)... 185.125.190.83, 91.189.91.83, 91.189.91.82, ...
Connecting to security.ubuntu.com (security.ubuntu.com)|185.125.190.83|:80... connected.
2025-01-21 18:03:11 ERROR 404: Not Found.
unfortunatly, beta version also needs the old openssl 1.1.1
Where can i find this old version libssl1.1.1? and openSSL_1_1_1?
I am quite “surprised” that the default Domoticz installation procedure is outdated and there is not a quick fix. Is docker the new default?
How many new users have already dropped out here?
I used this topic to install libssl1
https://stackoverflow.com/questions/721 ... 4#72633324
The package depends on your hardware architecture as explained in the answer. The latest version can be found here: http://nz2.archive.ubuntu.com/ubuntu/po ... l/?C=M;O=D
I used the amd64 version.
wget http://nz2.archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
yes!
thanks a lot Walter
thanks a lot Walter
Truffe13
- Domoticz version: 2024.7
I had the same issue when trying to install the wiki (pre-built installation - https://wiki.domoticz.com/Linux#Use_pre ... stallation) on Ubuntu Server 24.04.2 LTS
Domoticz needed to have libssl11 AND open ssh 1.1 installed
I solved with the following :
then
Then install domoticz (version 2024.7)
Hope it will help.
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.24_amd64.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1f-1ubuntu2.24_amd64.deb
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.24_amd64.deb
sudo dpkg -i openssl_1.1.1f-1ubuntu2.24_amd64.deb
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
Dave21w
- Domoticz version: Stable
Although I don't disagree with your comments I think you were a little harsh. Domoticz is a fantastic piece of software which is given away for free and alot of people give up their own time to support and make it a good as possible. I for one am very greatful for this and the support from the forum, give them a little latitude when things don't go right for you straight away.
Thanks Guys.
Thanks Guys.
- gizmocuz
The problem is with users using the old Debian version, they use a different SSL library.
Actually, I find the problem in the OpenSSL library as it seems it is not backwards compatible
We have this issue for quite some time, and it will be addressed with the upcoming stable version, but this will users require to upgrade their system.
Another option, just use the docker install, there are no dependencies! (Thats why they invented it)
ChriWo
- Domoticz version: 2022.1
I had the same problem with Debian 12.x I solved it like this:
First get ssl 1.1
Install ssl 1.1
after that install Domoticz
First get ssl 1.1
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1w-0+deb11u2_amd64.debCode: Select all
sudo dpkg -i libssl1.1_1.1.1w-0+deb11u2_amd64.debCode: Select all
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"-
nonecz
OH I got it,
1. get the package from http://security.debian.org/debian-secur ... o/openssl/
wget http://security.debian.org/debian-secur ... _amd64.deb
2. install
sudo dpkg -i libssl1.1_1.1.1w-0+deb11u3_amd64.deb
installation fixed. Thank you! This controller looks alive, thanks good.
2. install
Users browsing this forum: Dave21w and 1 guest
