it has been a while since I have been playing the last time with Domoticz, many private problems and now getting back on track.
still a Newbie
any way
I am now busy trying to get back to Domoticz and was looking to it at a new angle.
Because I am also busy with playing with a HP Proliant DL380 G7, purly for playing and learning no big plans yet.
So via VM it has currently a working Minecraft server (private local network)
there is also a Windows Server 2019 running on it.
It is all for new me but having fun.
Now I had the following idea to put also domoticz on it, been searching the internet had bad luck finding real good info and got stuck.
Sofar I managed to put debian-10.4.0-i386 on it.
Now I tried after this to put Domoticz on it and then it went all the wrong way.
I was trying to partly follow https://sancla.com/domoticz/domoticz-on ... e-vsphere/
first i was fighting with the SU access, managed to get that done correctly but then when I basically got to the last step to install Domoticz it went wrong.
I did "curl -sSL install.domoticz.com | sudo bash"
and the result was:
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?c ... chine=i686 [following]
--2020-07-28 09:42:00-- https://www.domoticz.com/download.php?c ... chine=i686
Connecting to www.domoticz.com (www.domoticz.com)|104.31.78.142|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://releases.domoticz.com/releases/ ... x_i686.tgz [following]
--2020-07-28 09:42:00-- https://releases.domoticz.com/releases/ ... x_i686.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 146.185.159.228, 2a03:b0c0:0:1010::480:1001
Connecting to releases.domoticz.com (releases.domoticz.com)|146.185.159.228|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2020-07-28 09:42:00 ERROR 404: Not Found.
And I got stuck and fully lost
where am I going wrong
is there someone that wants to help this newbie back on the right track?
