I 'm looking for a way to process multiple HTTP resonses of different openurl results.
E.g :
Open 2 different graph API calls for 2 different devices (idx 1 and idx2)
url1 = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=graph&sensor=counter&range=year&idx=' .. id1
dz.openURL({ url = url1, callback = scriptVar1 })
url2 = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=graph&sensor=counter&range=month&idx=' .. id2
dz.openURL({ url = url2, callback = scriptVar2 })
When I have only one url call, I process the results like this:
-- main
if item.isHTTPResponse and item.isJSON then
updateTextSensor(processResult(item.json))
elseif item.isTimer then
callYearGraph(idx1)
dz.log(' Error while retrieving elektra data. Result is ' .. item.statusText ..' ; Response is: ' .. item.data)
I know that the result of ONE openurl call is in item.json.
Can somebody give me an example of processing TWO url calls using TWO item.json tables with the different callback methods?
Thanks in advance, InfoEd
Access multiple json.item objects
- Domoticz version: 2026.3
Re: Access multiple json.item objects
You have to check the trigger eg
if item.trigger == 'scriptVar1' then
-- do your scrptvar 1 thing
elseif item.trigger == 'scriptVar2' then
-- do your scrptvar 2 thing
callYearGraph(idx1)
endDomoticz running on Udoo X86 (on Ubuntu)
- Ragdag
Here is an actual script I use to read my Dell iDRAC data of 2 different end points
Description:
This script polls an iDRAC interface for thermal and HDD status, updates Domoticz devices accordingly,
and logs relevant data. Uses HTTP requests to retrieve JSON data and ensures device existence before updates.
-- Constants and configuration
local scriptName = 'iDRAC_Monitor'
local config = {
baseUrl = 'https://192.168.2.202',
auth = 'Basic xxxxxxxx',
deviceIds = { inletTemp = 395, exhaustTemp = 396, cpu1Temp = 397, fan1Speed = 3008, hddPowerState = 4105, hddPowerStateText = 4104 },
endpoints = {
thermal = '/redfish/v1/Chassis/System.Embedded.1/Thermal',
hddStatus = '/redfish/v1/Systems/System.Embedded.1/Storage/RAID.Integrated.1-1/Drives/Disk.Bay.1:Enclosure.Internal.0-1:RAID.Integrated.1-1'
local deviceCache = {}
local logging = { marker = scriptName }
-- Utility functions
local function getDevice(domoticz, id)
if not deviceCache[id] then deviceCache[id] = domoticz.devices(id) end
return deviceCache[id]
local function updateDevice(domoticz, id, value, action, errorMsg)
local device = getDevice(domoticz, id)
if not device or value == nil or value == -999 then
domoticz.log(errorMsg, domoticz.LOG_ERROR)
return
if action == 'updateText' then device.updateText(value)
elseif action == 'updateTemperature' then device.updateTemperature(value)
elseif action == 'updateCustomSensor' then device.updateCustomSensor(value)
elseif action == 'switchOn' then device.switchOn()
elseif action == 'switchOff' then device.switchOff()
local function makeRequest(domoticz, endpoint, callback)
domoticz.openURL({ url = config.baseUrl .. endpoint, method = 'GET', headers = { ['Authorization'] = config.auth }, callback = callback })
-- Data processing
local function processThermalData(domoticz, data)
local updates = {
[config.deviceIds.inletTemp] = -999, [config.deviceIds.exhaustTemp] = -999, [config.deviceIds.cpu1Temp] = -999, [config.deviceIds.fan1Speed] = -999
for _, t in ipairs(data.Temperatures or {}) do
if t.Name:find('Inlet Temp') then updates[config.deviceIds.inletTemp] = t.ReadingCelsius
elseif t.Name:find('Exhaust Temp') then updates[config.deviceIds.exhaustTemp] = t.ReadingCelsius
elseif t.Name:find('CPU1 Temp') then updates[config.deviceIds.cpu1Temp] = t.ReadingCelsius
for _, f in ipairs(data.Fans or {}) do
if f.Name:find('Fan1') then updates[config.deviceIds.fan1Speed] = f.Reading end
for id, value in pairs(updates) do
updateDevice(domoticz, id, value, id == config.deviceIds.fan1Speed and 'updateCustomSensor' or 'updateTemperature', 'Error reading thermal data')
local function processHDDData(domoticz, data)
local status = data.Oem and data.Oem.Dell and data.Oem.Dell.DellPhysicalDisk.PowerStatus
if status then
updateDevice(domoticz, config.deviceIds.hddPowerState, status == 'Spun-Up', status == 'Spun-Up' and 'switchOn' or 'switchOff', 'Error setting HDD state')
updateDevice(domoticz, config.deviceIds.hddPowerStateText, status, 'updateText', 'Error setting HDD state text')
domoticz.log('Invalid HDD data format', domoticz.LOG_ERROR)
-- Main script
timer = { 'every 5 minutes' },
httpResponses = { scriptName .. '_thermal', scriptName .. '_hdd' }
logging = logging,
makeRequest(domoticz, config.endpoints.thermal, scriptName .. '_thermal')
makeRequest(domoticz, config.endpoints.hddStatus, scriptName .. '_hdd')
elseif item.isJSON then
local data = item.json
if data then
if item.callback == scriptName .. '_thermal' then processThermalData(domoticz, data)
elseif item.callback == scriptName .. '_hdd' then processHDDData(domoticz, data)
domoticz.log('Invalid response received', domoticz.LOG_ERROR)
