Access multiple json.item objects
infoed
Post by infoed »
I 'm looking for a way to process multiple HTTP resonses of different openurl results.
E.g :
Open 2 different graph API calls for 2 different devices (idx 1 and idx2)
url1 = dz.settings['Domoticz url'] .. '/json.htm?type=command&param=graph&sensor=counter&range=year&idx=' .. id1
dz.openURL({ url = url1, callback = scriptVar1 })
url2 = dz.settings['Domoticz url'] .. '/json.htm?type=command&param=graph&sensor=counter&range=month&idx=' .. id2
dz.openURL({ url = url2, callback = scriptVar2 })
When I have only one url call, I process the results like this:
-- main
if item.isHTTPResponse and item.isJSON then
updateTextSensor(processResult(item.json))
elseif item.isTimer then
callYearGraph(idx1)
dz.log(' Error while retrieving elektra data. Result is ' .. item.statusText ..' ; Response is: ' .. item.data)
I know that the result of ONE openurl call is in item.json.
Can somebody give me an example of processing TWO url calls using TWO item.json tables with the different callback methods?
Thanks in advance, InfoEd
Domoticz version: 2026.3
Re: Access multiple json.item objects
You have to check the trigger eg
  if item.trigger ==  'scriptVar1' then
  -- do your scrptvar 1 thing
  elseif item.trigger ==  'scriptVar2' then
  -- do your scrptvar 2 thing
   callYearGraph(idx1)
Ragdag
Post by Ragdag »
Here is an actual script I use to read my Dell iDRAC data of 2 different end points
Description:
This script polls an iDRAC interface for thermal and HDD status, updates Domoticz devices accordingly,
and logs relevant data. Uses HTTP requests to retrieve JSON data and ensures device existence before updates.
-- Constants and configuration
local scriptName = 'iDRAC_Monitor'
local config = {
    baseUrl = 'https://192.168.2.202',
    auth = 'Basic xxxxxxxx',
    deviceIds = { inletTemp = 395, exhaustTemp = 396, cpu1Temp = 397, fan1Speed = 3008, hddPowerState = 4105, hddPowerStateText = 4104 },
    endpoints = {
        thermal = '/redfish/v1/Chassis/System.Embedded.1/Thermal',
        hddStatus = '/redfish/v1/Systems/System.Embedded.1/Storage/RAID.Integrated.1-1/Drives/Disk.Bay.1:Enclosure.Internal.0-1:RAID.Integrated.1-1'
local deviceCache = {}
local logging = { marker = scriptName }
-- Utility functions
local function getDevice(domoticz, id)
    if not deviceCache[id] then deviceCache[id] = domoticz.devices(id) end
    return deviceCache[id]
local function updateDevice(domoticz, id, value, action, errorMsg)
    local device = getDevice(domoticz, id)
    if not device or value == nil or value == -999 then
        domoticz.log(errorMsg, domoticz.LOG_ERROR)
        return
    if action == 'updateText' then device.updateText(value)
    elseif action == 'updateTemperature' then device.updateTemperature(value)
    elseif action == 'updateCustomSensor' then device.updateCustomSensor(value)
    elseif action == 'switchOn' then device.switchOn()
    elseif action == 'switchOff' then device.switchOff()
local function makeRequest(domoticz, endpoint, callback)
    domoticz.openURL({ url = config.baseUrl .. endpoint, method = 'GET', headers = { ['Authorization'] = config.auth }, callback = callback })
-- Data processing
local function processThermalData(domoticz, data)
    local updates = {
        [config.deviceIds.inletTemp] = -999, [config.deviceIds.exhaustTemp] = -999, [config.deviceIds.cpu1Temp] = -999, [config.deviceIds.fan1Speed] = -999
    for _, t in ipairs(data.Temperatures or {}) do
        if t.Name:find('Inlet Temp') then updates[config.deviceIds.inletTemp] = t.ReadingCelsius
        elseif t.Name:find('Exhaust Temp') then updates[config.deviceIds.exhaustTemp] = t.ReadingCelsius
        elseif t.Name:find('CPU1 Temp') then updates[config.deviceIds.cpu1Temp] = t.ReadingCelsius
    for _, f in ipairs(data.Fans or {}) do
        if f.Name:find('Fan1') then updates[config.deviceIds.fan1Speed] = f.Reading end
    for id, value in pairs(updates) do
        updateDevice(domoticz, id, value, id == config.deviceIds.fan1Speed and 'updateCustomSensor' or 'updateTemperature', 'Error reading thermal data')
local function processHDDData(domoticz, data)
    local status = data.Oem and data.Oem.Dell and data.Oem.Dell.DellPhysicalDisk.PowerStatus
    if status then
        updateDevice(domoticz, config.deviceIds.hddPowerState, status == 'Spun-Up', status == 'Spun-Up' and 'switchOn' or 'switchOff', 'Error setting HDD state')
        updateDevice(domoticz, config.deviceIds.hddPowerStateText, status, 'updateText', 'Error setting HDD state text')
        domoticz.log('Invalid HDD data format', domoticz.LOG_ERROR)
-- Main script
        timer = { 'every 5 minutes' },
        httpResponses = { scriptName .. '_thermal', scriptName .. '_hdd' }
    logging = logging,
            makeRequest(domoticz, config.endpoints.thermal, scriptName .. '_thermal')
            makeRequest(domoticz, config.endpoints.hddStatus, scriptName .. '_hdd')
        elseif item.isJSON then
            local data = item.json
            if data then
                if item.callback == scriptName .. '_thermal' then processThermalData(domoticz, data)
                elseif item.callback == scriptName .. '_hdd' then processHDDData(domoticz, data)
            domoticz.log('Invalid response received', domoticz.LOG_ERROR)
