blockly mailing snapthot camera issue
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
gbonny
Post by gbonny »
Version 2024.7
Platform Ubuntu 22.04 LTS VM on ESXi 7
Description:
Hi, I'm trying to set up the following blockly.
What is working: doorbell button is pressed (connected to my fibaro smart implant) both chimes ring.
What is not working:
1. the time is ignored for one of the chimes. I expect it shouldn't ring between 18.55h - 07.05h. (I don't want to wake the kids during the night/evening)
2. there is no snapshot sent via email. The log throws an error:
2024-10-29 20:56:17.884 Error: SMTP Mailer: Error sending Email to: <[email protected]> !
2024-10-29 20:56:17.884 Error: libcurl: (56)
2024-10-29 20:56:17.884 Error: Failure when receiving data from the peer
I've setup email in settings and receive notifications normally. I have checked "Snapshots as attachments (Gmail)."
When "Snapshots as attachments (Gmail)" is unchecked I receive the image in alphabetical-format/base64(?) encoded.
I can see the image clearly in Camera settings, it's a Dahua, image URL: cgi-bin/snapshot.cgi?Channel=1
Is there anything I can do on my side? Has someone else the same problem? I haven't set it up on earlier versions of Domoticz, just now.
Domoticz 2024.7 on Ubuntu 22.04 LTS VM on ESXi 7
SolarEdge Web API, P1 meter, RFXCOM433E, OpenZWave via ZMEEUZB1, MQTT AD Client Gateway ZWave-JS-UI, Philips Hue bridge, Kodi Media server, Panasonic TV, OWM, BuienRadar and HTTP/HTTPS poller Watermeter
Domoticz version: 2024.7
Re: blockly mailing snapthot camera issue
Technically sending snapshots is working with a Gmail account. I use it too. But perhaps there is some local storage going wrong?As you seem to have Ubuntu running as a VM?
As a test you can also use a dummy switch and attach it to the camera to have a snapshot sent. You are able to see the camera images in Domoticz?
gbonny
Post by gbonny »
waltervl wrote: Wednesday 30 October 2024 0:35 Technically sending snapshots is working with a Gmail account. I use it too. But perhaps there is some local storage going wrong?As you seem to have Ubuntu running as a VM?
I have a Domoticz service in /etc/systemd/system/domoticz.service:
[Unit]
       Description=domoticz_service
[Service]
       User=domoticz
       Group=domoticz
       ExecStart=/home/domoticz/domoticz/domoticz -www 0 -sslwww 443 -sslcert /home/domoticz/domoticz/server_cert.pem -log /var/log/domoticz.log
       WorkingDirectory=/home/domoticz
       # Give the right to open priviliged ports. This allows you to run on a port <1024 without root permissions (user/group setting above)
       # The following works on Ubuntu 18.04
       AmbientCapabilities=CAP_NET_BIND_SERVICE
       Restart=on-failure
       RestartSec=1m
       #StandardOutput=null
[Install]
       WantedBy=multi-user.target
Domoticz is running under user Domoticz. Domoticz files are located in /home/domoticz/domoticz
domoticz1:/home/domoticz/domoticz$ ps aux | grep domoticz
domoticz 844 1.0 7.9 2111772 77536 ? Ssl 10:12 0:25 /home/domoticz/domoticz/domoticz -www 0 -sslwww 443 -sslcert /home/domoticz/domoticz/server_cert.pem -log /var/log/domoticz.log
domoticz1:/home/domoticz/domoticz$ ls -liah
total 44M
526129 drwxr-xr-x   8 domoticz domoticz 4.0K Oct 30 10:56 .
557423 drwxr-xr-x   9 domoticz domoticz 4.0K Jul 19 09:59 ..
524699 drwxr-xr-x   2 domoticz domoticz 4.0K Oct 23 20:17 backups
557468 drwxr-xr-x 123 domoticz domoticz 4.0K May  2 16:45 Config
525387 -rw-r--r--   1 domoticz domoticz  312 Oct 30 10:56 domocookie.txt
524919 -rwxr-xr-x   1 domoticz domoticz  18M Jul 13 17:06 domoticz
556558 -rw-r--r--   1 domoticz domoticz  12M Oct 30 10:55 domoticz.db
526431 -rw-r--r--   1 domoticz domoticz  32K Oct 30 10:56 domoticz.db-shm
524729 -rw-r--r--   1 domoticz domoticz  15M Oct 30 10:56 domoticz.db-wal
525095 -rw-r--r--   1 domoticz domoticz 5.8K Apr 25  2023 domoticz.sh
411151 drwxr-xr-x   4 domoticz domoticz 4.0K Oct 19  2022 dzVents
524992 -rw-r--r--   1 domoticz domoticz 117K Jul 13 17:02 History.txt
525028 -rw-r--r--   1 domoticz domoticz  35K Oct 19  2022 License.txt
524851 -rw-r--r--   1 domoticz domoticz  223 Oct 28 21:15 ozwcp.poll.XXXXXX.xml
525324 -rw-r--r--   1 domoticz domoticz 118K Apr  2  2023 ozwcp.stat.XXXXXX
525160 -rw-r--r--   1 domoticz domoticz   53 Apr 21  2021 ozwcp.testheal.XXXXXX
557544 drwxr-xr-x   4 domoticz domoticz 4.0K Apr 13  2021 plugins
411080 drwxr-xr-x   9 domoticz domoticz 4.0K Apr  3  2024 scripts
525109 -rw-r--r--   1 domoticz domoticz 3.4K Oct 19  2022 server_cert.pem
525125 -rwxr-xr-x   1 domoticz domoticz 1.8K Jan  2  2024 updatebeta
526312 -rwxr-xr-x   1 domoticz domoticz 1.8K Jan  2  2024 updaterelease
552691 drwxr-xr-x  14 domoticz domoticz 4.0K Jun 20 07:17 www
Which folder and what permissions should I look after?
I am able to view the snapshot and stream video in Domoticz Camera's.
Can you give more details on your suggestion: "As a test you can also use a dummy switch and attach it to the camera to have a snapshot sent"
As you suggested elsewhere this gives me also status OK:
https://domoticz1/json.htm?type=command&param=emailcamerasnapshot&camidx=1&subject=test
Then it seems perhaps an issue with blocky. I don't use that.
But as the Camara wiki states you can link a (dummy) switch to a camera so when that switch is switched a screenshot can be sent. If that works it is a blockly issue.
https://www.domoticz.com/wiki/Camera_Se ... ch.2FLight
gbonny
Post by gbonny »
waltervl wrote: Wednesday 30 October 2024 14:49 Then it seems perhaps an issue with blocky. I don't use that.
Thanks for the hint. I just did that, unfortunately the same error pops up in the Log, so it doesn't seem to be a Blockly issue..
