LUA syntax for textdevice
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi in dzVents I use syntax for textdevice like:
domoticz.devices(1554).updateText('humidityTmin5: ' .. humidityTmin5)
That's OK. But what's a LUA syntax to update the textdevice?
Why? Well I am trying to use the domoticz LUA script for vent regulation based upon humidity but it fails.
Now I want to monitor the VAR's using a textdevice like:
domoticz.devices(1554).updateText('humidityTmin5: ' .. humidityTmin5 .. 'humidityTmin10: ' .. humidityTmin10 .. 'Humidity delta: ' .. delta .. 'humCounter:' .. humCounter .. 'fanFollowsProgram:' .. fanFollowsProgram )
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2024.7
Re: LUA syntax for textdevice
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
        local device = domoticz.devices(40) --  text device
        local text = 'Str1 <br/>  Str2  <br/> Str3'
        local style = '<span style="color: red;">' .. text .. '</span>'
        device.updateText(style)
habahabahaba wrote: Tuesday 07 May 2024 20:04
This is the dzvents syntax, not the Lua syntax.
BartSr
Post by BartSr »
@Waltervl
Thanks for pointing in direction for solution.
Should someone has converted the dz LUA script already in dzVents?
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr wrote: Wednesday 08 May 2024 19:51 @Waltervl
-Bart
What script are you talking about? link?
BartSr
Post by BartSr »
https://www.domoticz.com/wiki/Humidity_control
meanwhile I face strange behaviour with this script (in fact with the fanswitch)
it happened today that the fan got a switch-on command. The fan-switch icon showd fan is running. When I checked the fan itselves it appeared fan was not running.
Than I manually switched off the fan (via dz fan-icon) and switched on again causing the fan to start as expected.
Meanwhile later on same situation. Now I didnot do any thing manual . A few minutes later dz switched off the fan.
Weird control for me...
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Here the equivalent for dzvents is discussed: https://www.domoticz.com/forum/viewtopic.php?t=16765
