LUA syntax for textdevice
BartSr
Domoticz version: V2024.3
Post by BartSr »
Hi in dzVents I use syntax for textdevice like:
domoticz.devices(1554).updateText('humidityTmin5: ' .. humidityTmin5)
That's OK. But what's a LUA syntax to update the textdevice?
Why? Well I am trying to use the domoticz LUA script for vent regulation based upon humidity but it fails.
Now I want to monitor the VAR's using a textdevice like:
domoticz.devices(1554).updateText('humidityTmin5: ' .. humidityTmin5 .. 'humidityTmin10: ' .. humidityTmin10 .. 'Humidity delta: ' .. delta .. 'humCounter:' .. humCounter .. 'fanFollowsProgram:' .. fanFollowsProgram )
TIA
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 espeasy
MQTT
Domoticz version: 2024.7
Re: LUA syntax for textdevice
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
        local device = domoticz.devices(40) --  text device
        local text = 'Str1 <br/>  Str2  <br/> Str3'
        local style = '<span style="color: red;">' .. text .. '</span>'
        device.updateText(style)
habahabahaba wrote: Tuesday 07 May 2024 20:04
This is the dzvents syntax, not the Lua syntax.
BartSr
Post by BartSr »
@Waltervl
Thanks for pointing in direction for solution.
Should someone has converted the dz LUA script already in dzVents?
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
BartSr wrote: Wednesday 08 May 2024 19:51 @Waltervl
-Bart
What script are you talking about? link?
BartSr
Post by BartSr »
https://www.domoticz.com/wiki/Humidity_control
meanwhile I face strange behaviour with this script (in fact with the fanswitch)
it happened today that the fan got a switch-on command. The fan-switch icon showd fan is running. When I checked the fan itselves it appeared fan was not running.
Than I manually switched off the fan (via dz fan-icon) and switched on again causing the fan to start as expected.
Meanwhile later on same situation. Now I didnot do any thing manual . A few minutes later dz switched off the fan.
Weird control for me...
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave
OTGW
Tasmota
Esp8266 espeasy
MQTT
Here the equivalent for dzvents is discussed: https://www.domoticz.com/forum/viewtopic.php?t=16765
