DZvents power get negative at 00:00
rolfie23
Domoticz version: 2024.7
Post by rolfie23 »
I have the following script running with succes for calculate total usage for few seprated led strips. I use the script for different uses, but there is one problem I already play with a long time but didn't find any solution yet.
My scripting is not the best, but what i archieved already in domoticz i'm really proud on!
The script is:
--	on = {
--	    timer = { 'at 00:00' }
		devices = {
			'$Aquarium verlichting Rood',
	execute = function(dz, item)
	    local RoodToday = dz.devices(451).WhToday
	    local GroenToday = dz.devices(454).WhToday
	    local BlauwToday = dz.devices(457).WhToday
	    local WitToday = dz.devices(460).WhToday
		local TotaalToday = RoodToday + GroenToday + BlauwToday + WitToday
		local RoodPower = dz.devices(451).actualWatt
	    local GroenPower = dz.devices(454).actualWatt
	    local BlauwPower = dz.devices(457).actualWatt
	    local WitPower = dz.devices(460).actualWatt
		local Power = RoodPower + GroenPower + BlauwPower + WitPower
	    if dz.time.matchesRule('at 00:05-23:59') then
            dz.devices(1174).updateElectricity(Power,TotaalToday)
--        if dz.time.matchesRule('at 00:00') then
--          dz.devices(1174).updateElectricity(0,0)
--        end
You see, i already tried sending a 0 at midnight what doesn't work. Also different times around midnight, found that as solution but doesn't work.
In the picture below you see the total usage at midnight getting negative.
Here some information about the switch where it's sending to:
    "ActTime": 1714635427,
    "AstrTwilightEnd": "23:50",
    "AstrTwilightStart": "03:26",
    "CivTwilightEnd": "21:50",
    "CivTwilightStart": "05:27",
    "DayLength": "15:03",
    "NautTwilightEnd": "22:42",
    "NautTwilightStart": "04:35",
    "ServerTime": "2024-05-02 09:37:07",
    "SunAtSouth": "13:38",
    "Sunrise": "06:07",
    "Sunset": "21:10",
    "app_version": "2024.2",
    "result": [
            "AddjMulti": 1,
            "AddjMulti2": 1,
            "AddjValue": 0,
            "AddjValue2": 0,
            "BatteryLevel": 255,
            "CounterToday": "0.005 kWh",
            "CustomImage": 101,
            "Data": "0.005 kWh",
            "Description": "",
            "EnergyMeterMode": "0",
            "Favorite": 1,
            "HardwareDisabled": false,
            "HardwareID": 6,
            "HardwareName": "Dummy",
            "HardwareType": "Dummy (Does nothing, use for virtual switches only)",
            "HardwareTypeVal": 15,
            "HaveTimeout": false,
            "ID": "00083174",
            "Image": "Aquarium",
            "LastUpdate": "2024-05-02 09:37:06",
            "Name": "Aquarium verlichting verbruik",
            "Notifications": "false",
            "PlanID": "0",
            "PlanIDs": [
                0
            "Protected": false,
            "ShowNotifications": true,
            "SignalLevel": "-",
            "SubType": "kWh",
            "SwitchTypeVal": 0,
            "Timers": "false",
            "Type": "General",
            "TypeImg": "current",
            "Unit": 1,
            "Usage": "0.46 Watt",
            "Used": 1,
            "XOffset": "0",
            "YOffset": "0",
            "idx": "1174"
    "status": "OK",
    "title": "Devices"
Energy read is "from device" and not on "computed". It works on Computed, but the difference with the real calculation is for my purpose to big.
For now, i delete the value and the day value get's correct. But doing this every day is a little bit to mucht work so I hope someone can help me with the script to make it workable!
Re: DZvents power get negative at 00:00
You should add the current TotalWh of your total device. The Energy should not go zero every day but a runing increasing value (like your home energy meter)
So add in the begin of your script
local TotaalWh = dz.devices(1174).TotalWh
Then modify your update line to
dz.devices(1174).updateElectricity(Power,TotaalToday+TotaalWh)
FlyingDomotic
Post by FlyingDomotic »
Electricity is counted as cumulative Wh (even if displayed as kWh).
Depending on values returned by your module, technic is different.
If values you get are cumulative but reset at some time (as midnight), you should write some code which:
- initialize saved value to zero
- read current value
- if current value is greater or equal to saved one, add the difference between current and saved to total
- else only add current value to total (as it has been reset to zero by device)
if values you get are instantaneous ones, you must first convert them to hourly values, multiplying them by (3600/<number of seconds since last read>), then adding them to total. Note in this case that for stable consumption, this may make it, but if values vary too much, or interval is too long, result will be not so good.
rolfie23
Post by rolfie23 »
FlyingDomotic wrote: Thursday 02 May 2024 12:56 Electricity is counted as cumulative Wh (even if displayed as kWh).
My scripting is not so good, but the values comes from Shelly devices. Maybe that can help for an solution?
FlyingDomotic
I don't known Shelly original firmware (I only use Shelly 1PM with my own code), so I can't tell how it works.
However, reading your code, I can imagine that devices 451, 454, 457 and 460 are electricity counters.
If that's the case, you may try replacing .WhToday by .WhTotal in your sketch, as device may already also return the incremental counter.
If this is not the case, I can provide an example which will implement my first hypothesis.
rolfie23
Post by rolfie23 »
waltervl wrote: Thursday 02 May 2024 10:52 You should add the current TotalWh of your total device. The Energy should not go zero every day but a runing increasing value (like your home energy meter)
Hello Walter,
Didn't see your message on my phone at first.
If I do that, I get the following error:
2024-05-02 15:16:58.505 Error: dzVents: Error: (3.1.8) ...ents/generated_scripts/Aquarium verlichting verbruik.lua:34: attempt to perform arithmetic on a nil value (local 'TotaalWh')
rolfie23
Post by rolfie23 »
Thanks waltervl found the solution thanks to you. Quite simple, and worked perfectly last night.
Maybe you have some adjustments on it, please let me know:
	    timer = { 'every minute' }
	    local RoodToday = dz.devices(451).WhTotal
	    local GroenToday = dz.devices(454).WhTotal
	    local BlauwToday = dz.devices(457).WhTotal
	    local WitToday = dz.devices(460).WhTotal
Looks perfect! I see a made a mistake in my TotaalWh definition but your solution is perfectly fine.
rolfie23
Post by rolfie23 »
waltervl wrote: Friday 03 May 2024 16:11 Looks perfect! I see a made a mistake in my TotaalWh definition but your solution is perfectly fine.
Great, thanks! Running few days now on multiple devices without any problem!
