If i try to update the Zigbee4Domoticz plugin, it fails. The plugin itself is working ok. There seems to be a owner issue somewere, i think. I have already removed and re-installed the plugin severaltimes, but everytime if there is a update the plugin fails to update. I can do a fetch and then rebase autostash, the plugin is updating. What can be the reason for the failing?
Zigbee4Domoticz fails update
Rik60
- Domoticz version: 2025.2
- Zigbee4Domoticz_fail.png (293.72 KiB) Viewed 1503 times
Re: Zigbee4Domoticz fails update
Indeed it looks like the update cannot go through, because found some changes.
can you try the following
Open a terminal window, and go to the plugin folder
If no error, then simply to the update via the WebUI
git can you try the following
git reset --hard
git pull
git status
Rik60
Thanks,
First, i have to 'sudo' the 3 commands, is that normal?
After the hard reset, pull and status and Domoticz service restart the plugin didn't start. I had to upgrade the requirements.txt as adviced. After that and domoticz restart the plugin is starting and updated.
- Zigbee4Domoticz_update.png (129.29 KiB) Viewed 1488 times
- Zigbee4Domoticz_error.png (46 KiB) Viewed 1488 times
- jacobsentertainment
- Domoticz version: 2021-1
Never mind, it's sorted again
Last edited by jacobsentertainment on Saturday 09 March 2024 22:14, edited 1 time in total.
keros
@Rik60, the sudo command is normal.
Can you please run sudo python3 -m pip install -r requirements.txt --upgrade and paste here the results of the command ?
@jacobsentertainment, it we be complicated to solve two problems in the same topic. Can you please open a new one ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
