switch device AND ledbutton
remko2000
Post by remko2000 »
I am setting up an MQTT display (button+https://button.plus/). There are also physical buttons on this. I want to switch lighting with 1 button. E.g. with payload: {"command": "switchlight", "idx": 268, "switchcmd": "Toggle" }
However, I also want that when this switch (idx268) is switched in domoticz, an MQTT command is sent from domoticz that turns on the LED of this button so that I see that the relevant light is on (and vice versa).
I can control this LED via topic 'buttonplus/wk1/button/7/ledrgb' + the RGB number such as '8323072'.
What is the best (and easiest) way to switch this in Domoticz? Script? What should this approximately look like? Unfortunately I don't know enough about domoticz to come up with a good solution for this.
Re: switch device AND ledbutton
What happened with this: https://www.domoticz.com/forum/viewtopic.php?p=313495
You can make a dzvents script that sends mqtt payloads to your button plus based on the domoticz trigger device. Similar as the script you used in the previous topic
remko2000
Post by remko2000 »
I listened to your advice and now use an execute shell. I use a script for each value. I tried converting such a script to this functionality:
        devices = {
            'lamp keukenkast'
    logging = {
        level = domoticz.LOG_INFO,
        marker = 'template',
        domoticz.log('Device ' .. device .. ' was changed', domoticz.LOG_INFO)
        domoticz.log(device.text)
        domoticz.executeShellCommand ( 'mosquitto_pub  -h 10.0.1.122 -p 1883 -t domoticz/out/ButtonPlus/wk7/btton/7/ledrgb/8323072 -m ' .. device.. '')
However, this gives error messages, so I am doing something wrong somewhere.....
Error:
2024-02-07 12:43:38.196 Error: dzVents: Error: (3.1.8) template: ...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:12: attempt to concatenate a table value (local 'device')
The RGB color number must also be sent as a 'raw' value, I don't know if this is done this way
Your device is an device object, So use device.name to log the device name in
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
The same probably for the device in the mosquitto_pub command.
What is the correct mosquitto_pub command to make the button change color?
I suppose it should be something like
mosquitto_pub  -h 10.0.1.122 -p 1883 -t domoticz/out/ButtonPlus/wk7/btton/7/ledrgb -m 8323072
or when rgb value as text
mosquitto_pub  -h 10.0.1.122 -p 1883 -t domoticz/out/ButtonPlus/wk7/btton/7/ledrgb -m "8323072"
t=mqtt topic
m= mqtt message, so the value to be set onto the topic.
Additional I would advise you to use mqtt explorer were you can look to the mqtt topics and also send messages to test. https://www.emqx.com/en/blog/connecting ... t-explorer
remko2000
Post by remko2000 »
I'm using mqtt explorer. With this command 'domoticz/out/buttonplus/wk1/button/1l/ledrgb' I can switch a buttonLed with the value ' 8323072' as a raw value.
I adjust my script:
        devices = {
            'Lamp keukenkast'
    logging = {
        domoticz.executeShellCommand ( 'mosquitto_pub  -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb -m 8323072' .. device.name.. '')
Nothing happened. I also tried:
'domoticz.executeShellCommand ( 'mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb -m "8323072"' .. device.name.. '')'
Same result (my log says ' 2024-02-07 17:22:57.095 Status: dzVents: Info: template: nil'
Scherm­afbeelding 2024-02-07 om 17.19.58.png (114.99 KiB) Viewed 1310 times
remko2000
Post by remko2000 »
I think I' almost there:
if I use in the sript:
domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb/ -m "8323072"')
I get in mqtt explorer: 'domoticz/out/buttonplus/wk1/button/1l/ledrgb/ 8323072'
there are 2 spaces in between, maybe this is the problem my buttonled doesn’t switch on?
This is sent as raw data with ' -m'?
Try
domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb/ -m 8323072')
remko2000
Post by remko2000 »
that gives the same result:
pikassent
Domoticz version: 2024.4b
Post by pikassent »
Try to remove the trailing slash:
domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb -m 8323072')
maybe you are publishing in topic domoticz/out/buttonplus/wk1/button/1l/ledrgb/<blank>
remko2000
Post by remko2000 »
pikassent wrote: Wednesday 07 February 2024 20:13 Hi,
That do the trick. Many thanx! When I switch off the led does not switch. I have to send ' off' or '0' when off. Is there a way to combine this in one script?
Just copy the execute shell command line and put the other mqtt command in it.
remko2000
Post by remko2000 »
I combined these two execute shell commands with this script:
        devices = {
            'device xx'
    		if (switch.state == 'On') then
    		--	domoticz.notify('Hey!', 'I am on!',
    		--	domoticz.PRIORITY_NORMAL)
    			domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1l/ledrgb -m 0')
    		--	domoticz.notify('Hey!', 'I am off!',
This works fine.
remko2000
Post by remko2000 »
correction; it doesn't work very well anyway. I get an error in my log that I cannot explain:
        devices = {
            'Beveiliging buttonplus schakelen'
    		    domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1r/ledrgb -m 8323072')
    			domoticz.executeShellCommand ('mosquitto_pub -h 10.0.1.122 -p 1883 -t domoticz/out/buttonplus/wk1/button/1r/ledrgb -m 0')
Error:
2024-02-12 16:06:27.153 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler buttonplusled1r
2024-02-12 16:06:27.153 Error: dzVents: Error: (3.1.8) ...cz/scripts/dzVents/generated_scripts/buttonplusled1r.lua:15: attempt to index a nil value (global 'device')
2024-02-12 16:06:27.723 Error: dzVents: Error: (3.1.8) An error occurred when calling event handler buttonplusled1r
2024-02-12 16:06:27.723 Error: dzVents: Error: (3.1.8) ...cz/scripts/dzVents/generated_scripts/buttonplusled1r.lua:15: attempt to index a nil value (global 'device')
What does this mean/what am I doing wrong?
The script also keeps running continuously and that is not the intention. The script only has to do its work in the event of a switch state change.....
The error is referring to line 15 (buttonplusled1r.lua:15) wich probably is the line
You have that 2 times in your script. But "device" is not known in your script. so nil value, as you you execute the script with
you better change that in
additional: device.text will also give an error because it should probably be device.name (String. Name of the device)
remko2000
Post by remko2000 »
thx, I adjust the 'switch' function.
This is my script now:
        devices = {
    		if (device.state == 'On') then
With this code it looks like the 'off' function keeps repeating:
2024-02-15 09:38:37.392 Status: dzVents: Info: Handling events for: "Beveiliging buttonplus schakelen", value: "Off"
2024-02-15 09:38:37.393 Status: dzVents: Info: ------ Start internal script: buttonplusled1r: Device: "Beveiliging buttonplus schakelen (QuinLED)", Index: 269
2024-02-15 09:38:37.393 Status: dzVents: Info: nil
2024-02-15 09:38:37.393 Status: dzVents: Info: ------ Finished buttonplusled1r
2024-02-15 09:38:37.394 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2024-02-15 09:38:37.705 Status: dzVents: Info: Handling events for: "Beveiliging buttonplus schakelen", value: "Off"
2024-02-15 09:38:37.705 Status: dzVents: Info: ------ Start internal script: buttonplusled1r: Device: "Beveiliging buttonplus schakelen (QuinLED)", Index: 269
2024-02-15 09:38:37.705 Status: dzVents: Info: nil
2024-02-15 09:38:37.705 Status: dzVents: Info: ------ Finished buttonplusled1r
2024-02-15 09:38:37.706 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Is there a way the script does nothing until the state of 'Beveiliging buttonplus schakelen' is changing?
according your script it should only be triggered when device 'Beveiliging buttonplus schakelen' is being switched.
PS
you still have a message like 2024-02-15 09:38:37.393 Status: dzVents: Info: nil
this is because of the lines
that should be changed into
domoticz.log(device.name)
as device.text is nothing..... so nil.
