Zigbee For Domoticz plugin how to upgrade on Win10
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Hi everybody.
Im using Domoticz on Win10 . Yesterday installed wesion 2024 and see the messages in log - "[WebServer] Deprecated RType (devices)"
The FAQ is saying that i need to upgrade the plugin (6.3.015)
But git-cmd gives some errors and webUI gives nothing.
Any advices how to do that?
Thanks.
pipiche
Re: Zigbee For Domoticz plugin how to upgrade on Win10
Post by pipiche »
You need to move to the folder where the plugin is installed
The best is to open a command window with adminoistrator access right
git pull
git checkout stable7
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
https://zigbeefordomoticz.github.io/wik ... e_7.1.html
habahabahaba
pipiche wrote: Thursday 01 February 2024 18:35 You need to move to the folder where the plugin is installed
git pull
git pull
I read the WiKi.
But as i said i have some error:
The attachment 2024-02-02_10-16-43.png is no longer available
pipiche
Post by pipiche »
This looks as a git corruption . Make sure you have the latest git installed on your system
you can try that
git update-index --refresh
if it doesn't work, I'm afraid that you will have to re-clone the repository
here is a pointer on the critical elements to backup/restore
https://zigbeefordomoticz.github.io/wik ... ackup.html
habahabahaba
Ok, i'll try later.
Thank you!
habahabahaba
So...
Reinstal the plugin completly to v 7.1
Got this errors:
The attachment 2024-02-02_12-45-32.png is no longer available
That is one of the wall switches. And now it does not respond to keystrokes :(
Came back to v 6.3 but the switch still not responds to keystrokes :(
And 2 teperature sensors are lost :(
pipiche
Post by pipiche »
those errors are not a big issue. I guess it is a Aqra/Xiaomi device. It might have left the network because the coordinator was not up during your migration.
So you have simply to re-pair it
habahabahaba
pipiche wrote: Friday 02 February 2024 12:03 those errors are not a big issue. I guess it is a Aqra/Xiaomi device. It might have left the network because the coordinator was not up during your migration.
Hi again :)
Thanks for your advising. Seems everything is working... except that one wall wired switch :(
I completly deleted it from Dz and plugin, rebooted system and tried to pair it again.
It working fine for the first 2 minutes and then the same errors:
2024-02-02 15:49:33.378 Status: ZigBee USB stick: [None] NEW OBJECT: 4b00 None
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 01 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 02 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: f2 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Request Simple Descriptor for Ep: 01
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 01 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 02 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: f2 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Request Simple Descriptor for Ep: 02
2024-02-02 15:49:36.658 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 1: 0000 (Basic)
2024-02-02 15:49:36.658 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 2: 0002
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 3: 0003 (Identify)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 4: 0004 (Groups)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 5: 0005 (Scenes)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 6: 0006 (On/Off)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 7: 0009 (Alarms)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 1: 000a (Time)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 2: 0019 (Over-the-Air Upgrade)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0001
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 07
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 02
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID 0104
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0100
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0x01 LQI: 152
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 1: 0000 (Basic)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 2: 0003 (Identify)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 3: 0004 (Groups)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 4: 0005 (Scenes)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0001
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 05
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID 0104
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0100
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0x02 LQI: 148
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 5: 0006 (On/Off)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 00
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 1: 0021
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0000
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 00
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 01
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID a1e0
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0061
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0xf2 LQI: 148
2024-02-02 15:49:49.123 Status: ZigBee USB stick: [3] NEW OBJECT: 4b00 Manufacturer Name: LUMI
2024-02-02 15:49:49.123 Status: ZigBee USB stick: [3] NEW OBJECT: 4b00 Model Name: lumi.switch.b2lc04
2024-02-02 15:51:47.713 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0201 Status: 00 DataType: 10 DataSize: 0001 Data: 01
2024-02-02 15:51:48.447 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00f0 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:49.025 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0200 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:49.525 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/02 Cluster: fcc0 Attribute: 0200 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:50.197 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0004 Status: 00 DataType: 21 DataSize: 0002 Data: 0004
So it turns on/off lights from Dz but the physical buttons stop working :(
I dont know the model of the switch. The log saying it Model Name: lumi.switch.b2lc04
but Parameters are like : {'AqaraOppleMode': 1, 'AqaraOpple_switch_power_outage_memory': 1, 'AqaraOpple_flip_indicator_light': 0, 'AqaraOpple_switch_operation_mode_opple': 0, 'AqaraOpple_aqara_switch_mode_switch': 1}
Any advises?
pipiche
Post by pipiche »
I suspect that something is not up-to-date in your case.
In the WebUI what is the Plugin Version number ? especially what do you have in [] ?
habahabahaba
Plugin: 7.1.008 [3.206]
habahabahaba
pipiche wrote: Friday 02 February 2024 14:31 I suspect that something is not up-to-date in your case.
So...? Any ideas?
Stil getting this error but switch start to work by itself :shock:
 2024-02-02 22:21:10.269 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023030000000123000000000223eb0000000323340200000421530005210500122109001521090006210000072102000821e000092106010a2100000b2100001321000014210000
2024-02-02 22:21:17.048 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 01:40:05.220 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023050000000123000000000223850100000323a5030000042174000521080012210a0015210a000621000007210200082179010921ba010a2100000b2100001321000014210000
2024-02-03 01:40:12.015 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 04:25:38.362 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023090000000123000000000223050200000323050500000421be000521150012210f0015210f0006210000072102000821f401092148020a2100000b2100001321000014210000
2024-02-03 04:25:45.203 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 07:44:00.741 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 00230f00000001230000000002239f0200000323790600000421e40005211b001221120015211200062100000721020008218b020921f9020a2100000b2100001321000014210000
2024-02-03 07:44:07.551 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 11:05:45.912 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023120000000123000000000223420300000323f507000004210d0105211d0012211800152118000621000007210200082128030921ad030a2100000b2100001321000014210000
2024-02-03 11:05:52.707 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 14:01:27.660 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023160000000123000000000223c703000003233309000004212f010521210012211c0015211c0006210000072102000821a903092144040a2100000b2100001321000014210000
2024-02-03 14:01:34.439 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 16:46:58.006 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 00231700000001230000000002234904000003236c0a000004215d010521230012212300152123000621000007210200082124040921d2040a2100000b2100001321000014210000
2024-02-03 16:47:04.832 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
