Zigbee For Domoticz plugin how to upgrade on Win10
- habahabahaba
- Domoticz version: 2024.4
Hi everybody.
Im using Domoticz on Win10 . Yesterday installed wesion 2024 and see the messages in log - "[WebServer] Deprecated RType (devices)"
The FAQ is saying that i need to upgrade the plugin (6.3.015)
But git-cmd gives some errors and webUI gives nothing.
Any advices how to do that?
Thanks.
Thanks.
Re: Zigbee For Domoticz plugin how to upgrade on Win10
You need to move to the folder where the plugin is installed
The best is to open a command window with adminoistrator access right
https://zigbeefordomoticz.github.io/wik ... e_7.1.html
git pull
git checkout stable7
git pull
sudo python3 -m pip install -r requirements.txt --upgrade- habahabahaba
I read the WiKi.pipiche wrote: Thursday 01 February 2024 18:35 You need to move to the folder where the plugin is installed
The best is to open a command window with adminoistrator access righthttps://zigbeefordomoticz.github.io/wik ... e_7.1.htmlCode: Select all
git pull git checkout stable7 git pull sudo python3 -m pip install -r requirements.txt --upgrade
But as i said i have some error:
- Spoiler: show
This looks as a git corruption . Make sure you have the latest git installed on your system
you can try that
if it doesn't work, I'm afraid that you will have to re-clone the repository
here is a pointer on the critical elements to backup/restore
https://zigbeefordomoticz.github.io/wik ... ackup.html
you can try that
git update-index --refreshhere is a pointer on the critical elements to backup/restore
- habahabahaba
Ok, i'll try later.
Thank you!
Thank you!
- habahabahaba
So...
Reinstal the plugin completly to v 7.1
Got this errors:
That is one of the wall switches. And now it does not respond to keystrokes
Came back to v 6.3 but the switch still not responds to keystrokes
And 2 teperature sensors are lost
Got this errors:
those errors are not a big issue. I guess it is a Aqra/Xiaomi device. It might have left the network because the coordinator was not up during your migration.
So you have simply to re-pair it
- habahabahaba
Hi againpipiche wrote: Friday 02 February 2024 12:03 those errors are not a big issue. I guess it is a Aqra/Xiaomi device. It might have left the network because the coordinator was not up during your migration.
Thanks for your advising. Seems everything is working... except that one wall wired switch
I completly deleted it from Dz and plugin, rebooted system and tried to pair it again.
It working fine for the first 2 minutes and then the same errors:
2024-02-02 15:49:33.378 Status: ZigBee USB stick: [None] NEW OBJECT: 4b00 None
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 01 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 02 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: f2 LQI: 152
2024-02-02 15:49:34.549 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Request Simple Descriptor for Ep: 01
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 01 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: 02 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Active Endpoint Response Ep: f2 LQI: 156
2024-02-02 15:49:36.158 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Request Simple Descriptor for Ep: 02
2024-02-02 15:49:36.658 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 1: 0000 (Basic)
2024-02-02 15:49:36.658 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 2: 0002
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 3: 0003 (Identify)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 4: 0004 (Groups)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 5: 0005 (Scenes)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 6: 0006 (On/Off)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 7: 0009 (Alarms)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 1: 000a (Time)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 2: 0019 (Over-the-Air Upgrade)
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0001
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 07
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 02
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID 0104
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0100
2024-02-02 15:49:36.673 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0x01 LQI: 152
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 1: 0000 (Basic)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 2: 0003 (Identify)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 3: 0004 (Groups)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 4: 0005 (Scenes)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0001
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 05
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID 0104
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0100
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0x02 LQI: 148
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster In 5: 0006 (On/Off)
2024-02-02 15:49:46.280 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 00
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster Out 1: 0021
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Application Version 0000
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster IN Count: 00
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Cluster OUT Count: 01
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ProfileID a1e0
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 ZDeviceID 0061
2024-02-02 15:49:46.530 Status: ZigBee USB stick: [-] NEW OBJECT: 4b00 Simple Descriptor Response EP: 0xf2 LQI: 148
2024-02-02 15:49:49.123 Status: ZigBee USB stick: [3] NEW OBJECT: 4b00 Manufacturer Name: LUMI
2024-02-02 15:49:49.123 Status: ZigBee USB stick: [3] NEW OBJECT: 4b00 Model Name: lumi.switch.b2lc04
2024-02-02 15:51:47.713 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0201 Status: 00 DataType: 10 DataSize: 0001 Data: 01
2024-02-02 15:51:48.447 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00f0 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:49.025 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0200 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:49.525 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/02 Cluster: fcc0 Attribute: 0200 Status: 00 DataType: 20 DataSize: 0001 Data: 00
2024-02-02 15:51:50.197 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 0004 Status: 00 DataType: 21 DataSize: 0002 Data: 0004I dont know the model of the switch. The log saying it Model Name: lumi.switch.b2lc04
but Parameters are like : {'AqaraOppleMode': 1, 'AqaraOpple_switch_power_outage_memory': 1, 'AqaraOpple_flip_indicator_light': 0, 'AqaraOpple_switch_operation_mode_opple': 0, 'AqaraOpple_aqara_switch_mode_switch': 1}
Any advises?
I suspect that something is not up-to-date in your case.
In the WebUI what is the Plugin Version number ? especially what do you have in [] ?
- habahabahaba
Plugin: 7.1.008 [3.206]
- habahabahaba
So...? Any ideas?pipiche wrote: Friday 02 February 2024 14:31 I suspect that something is not up-to-date in your case.
Stil getting this error but switch start to work by itself
2024-02-02 22:21:10.269 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023030000000123000000000223eb0000000323340200000421530005210500122109001521090006210000072102000821e000092106010a2100000b2100001321000014210000
2024-02-02 22:21:17.048 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 01:40:05.220 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023050000000123000000000223850100000323a5030000042174000521080012210a0015210a000621000007210200082179010921ba010a2100000b2100001321000014210000
2024-02-03 01:40:12.015 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 04:25:38.362 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023090000000123000000000223050200000323050500000421be000521150012210f0015210f0006210000072102000821f401092148020a2100000b2100001321000014210000
2024-02-03 04:25:45.203 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 07:44:00.741 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 00230f00000001230000000002239f0200000323790600000421e40005211b001221120015211200062100000721020008218b020921f9020a2100000b2100001321000014210000
2024-02-03 07:44:07.551 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 11:05:45.912 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023120000000123000000000223420300000323f507000004210d0105211d0012211800152118000621000007210200082128030921ad030a2100000b2100001321000014210000
2024-02-03 11:05:52.707 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 14:01:27.660 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 0023160000000123000000000223c703000003233309000004212f010521210012211c0015211c0006210000072102000821a903092144040a2100000b2100001321000014210000
2024-02-03 14:01:34.439 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
2024-02-03 16:46:58.006 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0048 Data: 00231700000001230000000002234904000003236c0a000004215d010521230012212300152123000621000007210200082124040921d2040a2100000b2100001321000014210000
2024-02-03 16:47:04.832 Error: ZigBee USB stick: ReadCluster - Error/unknow 4b00/01 Cluster: fcc0 Attribute: 00df Status: 00 DataType: 41 DataSize: 0047 Data: 16210000172100000c210000182100001e2100001f210000202100002221000023210000242000252300000000fa210000fb210000fc2300000000fd2300000000fe23c0001000
