User interface stopped
John
Post by John »
Yesterday my domoticz worked fine. this morning it stopped.
I try to post some detail;s, but this forum says:
You can’t post image, email or url links that are external to this domain. Please remove ... (can't add, because forum blocks this)
Please see the attachement for details.
Some help is very much appriciated
___
29/11 12:40: attachment added
29/11 12:56: I removed the tuyaha plugin from the plugin directory
29/11 12:59 attacgment added, I think Enever is a problem here. How to disable a device from the command line?
forum post 3.txt
(300 Bytes) Downloaded 30 times
forum post 2.txt
(11.59 KiB) Downloaded 28 times
forum post 1.txt
(4.55 KiB) Downloaded 36 times
FireWizard
Re: User interface stopped
Post by FireWizard »
Hello @John,
It seems that there is currently an issue with this plugin. At least @gizmocuz is preparing a modification.
see: https://github.com/domoticz/domoticz/co ... 90c8bbd797
Domoticz version: 2025.1
FireWizard wrote: Wednesday 29 November 2023 15:13 Hello @John,
I don't think this commit has anything to do with solving issues. It is a general update of internal error handling.
John
Post by John »
The solution proposed by @gizmocuz worked. There were issues with the exeception handling of the Enever plugin. Due to the fact I ran out of credits apparently the plugin blocked the domoticz. This was fixed in a beta release which I installed. Now I'm up and running again!
