Yesterday my domoticz worked fine. this morning it stopped.
I try to post some detail;s, but this forum says:
You can’t post image, email or url links that are external to this domain. Please remove ... (can't add, because forum blocks this)
Please see the attachement for details.
Some help is very much appriciated
___
29/11 12:40: attachment added
29/11 12:56: I removed the tuyaha plugin from the plugin directory
29/11 12:59 attacgment added, I think Enever is a problem here. How to disable a device from the command line?
User interface stopped
John
- forum post 3.txt
- (300 Bytes) Downloaded 59 times
- forum post 2.txt
- (11.59 KiB) Downloaded 56 times
- forum post 1.txt
- (4.55 KiB) Downloaded 61 times
- FireWizard
Re: User interface stopped
Hello @John,
It seems that there is currently an issue with this plugin. At least @gizmocuz is preparing a modification.
see: https://github.com/domoticz/domoticz/co ... 90c8bbd797
- Domoticz version: 2026.3
I don't think this commit has anything to do with solving issues. It is a general update of internal error handling.FireWizard wrote: Wednesday 29 November 2023 15:13 Hello @John,
John
The solution proposed by @gizmocuz worked. There were issues with the exeception handling of the Enever plugin. Due to the fact I ran out of credits apparently the plugin blocked the domoticz. This was fixed in a beta release which I installed. Now I'm up and running again!
