I noticed there is a new pi os available (bookworm). Is Domoticz already supported on bookworm?
In other words:
- Can i safely upgrade my system, or should i wait till it's supported?
- And if i upgrade: Are there attention points i need to take into account?
Bookworm
- Domoticz version: 2025.1
Re: Bookworm
Domoticz should run on Bookworm, no reason why it should not.
akamming
Re: Bookworm
tx, but also fully tested and supported on bookworm?waltervl wrote: Monday 27 November 2023 13:21 Domoticz should run on Bookworm, no reason why it should not.
Reason i'm asking that it is a big hassle to upgrade, so want to be 100% sure i can fix forward if there are any issues...
Re: Bookworm
If I search the forum I see people are using Domoticz on bookworm so a presume it works.
I dont know if it is officially tested, I suspect not as there is no official OS test. It depends on reports from other users reporting it works.
So it could well be that in the peripheral of Domoticz (bash/python/services) it could lead to issues. I already read about Bookworm it needs some special settings for some devices or python installs. But has in general nothing to do with Domoticz.
Perhaps buy a new SD card and install everything from new so you have a backup.
- McMelloW
- Domoticz version: V2024.1
Re: Bookworm
There are some issues with libssl.so.1.1 since bookworm is using libssl.so.3*
Better search for libssl.so.1.1 on this forum first before upgrading.
Greetings McMelloW
bonebuster
Re: Bookworm
for me Domoticz does not work on Bookworm
New intsall on pi4B
New intsall on pi4B
ERR_CONNECTION_REFUSED
Re: Bookworm
Check the log file of domoticz
- andreo
- Domoticz version: 2024.3
Re: Bookworm
Transfer everything to Docker, Bookworm runs here on a Raspberry 4.
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
