But after about 4 hours the tasmota switches reacting slower when switchting on/off.
1 hour later they stopped reacting when on/off.
Hopefully someone has an idea to resolve this.
Version: Domoticz 2023 2
Platform: Raspberry pi 4b 4gb ssd
Plugin/Hardware: see picture in the description
Description:
When system starts. All works fine. ZWave, RFXCom, Zigbee and Tasmota devices.
The incomming data is receiving correct, like electra ursage. kWh etc.
After restart Domoticz it's the same after a while.
I have problems with my Tasmota switches after update to new system.
Before I had OpenZWave and now Z-Wave-JS-UI.
For Zigbee2MQTT and ZWave-JS-UI, I have MQTT Auto Discovery Gateway with LAN interface.
For the Tasmota devices I use MQTT Client Gateway with LAN interface.
Tasmota with MQTT Auto Discovery did not working.
Maybe the problem is the 2 MQTT's installed at same time.
Before on old system I had OpenZWave and no MQTT auto discovery.
I testing with powerswitch tasmota versions 12 3 1 and 13 2 0.
Before I was going from old Raspberry pi 3b I had run a test Raspberry pi 4b.
After running ok for a few weeks, I was stept over to new main raspberry pi 4b with data from
the old Domoticz on the 3b.
I had updated the ZWave devices from OpenZwave to Z-Wave-JS-UI.
For test I have also run Home Assistant. The Tasmota device there working ok. !!
I have now running a script who calls domoticz to switch on a tasmota powerswitch.
and check how long it takes that the device is going on.
When to long, like 2 min or not on, automaticly restart Domoticz.
But this not nice
I use some Tasmota devices because the http calls that I make to the devices, outsite the raspberry.
I also tried to use tasmota devices with MQTT auto discovery, but it didn't work.
New system:
- Raspberry 4b 4gb memory. ssd.
- Domoticz Version: 2023 2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3 1 8
Python Version: 3 9 2 (default, Feb 28 2021, 17:03:44) [GCC 10 2 1 20210110]
- In snap:
zwave-js-ui: 9 2 3 1454eca
zwave-js: 12 2 1
- In docker
Zigbee2MQTT
Home Assistant 2023 11 1
Devices:
tasmota 13
Zwave 35
Zigbee 5
RFXCom 15
Plugins Domoticz installed:
