I have bought the new Hue Secure Contact sensor (door/window sensor), but it isn't showing up in Domoticz. A new motion sensor showed up immediately.
Is the Hue contact not supported? Or do I have to change a setting or something.
Hue Secure Contact sensor not showing up
- Domoticz version: 2025.1
Re: Hue Secure Contact sensor not showing up
With what integration in Domoticz are you working? Hue Bridge, Zigbee2MQTT, Zigbee4Domoticz Plugin, Conbee/Deconz?
nitpicker
- Domoticz version: 2022.2
I use the Hue bridge and all other things work flawless. Lights and motion sensors (also newly added ones).
There has been no functional changes to Philips Hue bridge the last years so probably not implemented yet. If you do not have C++ programming skills then you have to wait until someone with a Hue bridge and this sensor and programming skills has the same issue.
nitpicker
Too bad I'v no C++ programming skills...
Fyi, hue secure contact sensors are now implemented https://github.com/domoticz/domoticz/pull/6415
Merged into development. Hopefully a release soon.
Domoticz 2025.2 on Ubuntu 24.04 LTS VM (ESXi 7u3s)
SolarEdge/webAPI, SE2MQTT/modbus IP, Zigbee2MQTT/Sonoff ZB3.0+, ZWave-JS-UI/ZMEEUZB1, MQTT AD Client Gw, P1 mtr, RFXCOM433E, Philips Hue v2, Kodi, Panasonic TV, BuienRadar & Watermtr/HTTP/HTTPS poll
- gizmocuz
It's available already in the beta version
